Question about Bunn NHB Coffee Maker
How do you clean coffee maker? - Bunn NHB Coffee Maker
    President:
  • 662 Answers
Here's the official word from Bunn:
http://www.bunnathome.com/maintenance/velocity-brew/velocity-brew-cleaning-maintenance
Basic Cleaning
Daily washing and cleaning of the brew funnel and decanter after each use is required. Occasionally, wipe the outside of the brewer, including the area above the funnel, with mild, no citrus added dish soap and a damp cloth. The brew funnel and decanter are top rack dishwasher safe. For BTX brewers please see instructions on cleaning your thermal carafe.
Deliming
You should delime your BUNN brewer to clear any deposits that may have accumulated due to impurities in the water source. The frequency of deliming depends on the mineral content of your water.
NOTE - Unplug the brewer and let it cool down before deliming.
1. Remove the sprayhead by turning with your fingertips and set it aside.
2. Insert all but two inches of the flexible deliming tool (supplied) into the sprayhead tube. Call 800-352-2866 or see www.bunn.com for a replacement deliming tool.
3. Slide the tool in and out five or six times to loosen lime in the sprayhead tube. You may need to twist, push and use some force when inserting the tool, then remove.
4. Check the holes of the sprayhead. If plugged with mineral deposits or white flakes, they may be cleared by using a toothpick. Clean the sprayhead with a cloth and mild detergent. Rinse the sprayhead with water, then reinstall. Empty water from decanter.
5. Plug in the brewer and allow the water in the tank to reheat before using (approximately 15 minutes).
Periodic Cleaning
You should clean your BUNN brewer at least every 3 months. The frequency of cleaning depends on the mineral content of your water.
1. Slide an empty brew funnel into the brewer under the sprayhead and center an empty decanter on the base plate.
2. Open the lid and pour one quart of white vinegar into the top of the brewer; close the lid. Empty the decanter when liquid stops flowing from the funnel.
3. Allow the brewer to sit plugged in for two hours.
4. Unplug the brewer. Remove the brew funnel and sprayhead from the brewer. Clean the sprayhead with a cloth and mild detergent.
5. To drain the brewer, see details, OR to clear vinegar out of brewer without draining, pour a decanter of fresh, cold water through the brewer. With funnel in place, position decanter on base plate, then close the lid to allow the water to run through the brewer. After it has run through, empty decanter and repeat the process approximately 8 - 10 times. Proceed to step 9.
6. Cool the brewer by pouring a full decanter of fresh, cold water into the top of the brewer. Place decanter on the base plate and close the lid. When water has stopped flowing from the brewer, empty the decanter. Repeat this process and set the decanter aside.
7. Grasp the back of the brewer and turn it upside down over a sink. Most of the water in the tank will flow from the sprayhead tube opening. Some water may flow from the area around the top lid. Continue tipping the brewer until the flow stops.
8. Pour a decanter of water into the top of the brewer. Place the decanter on the base plate; close the lid and wait 3 minutes. Repeat this process with another decanter of water. Water will flow out of the funnel after the second decanter has been poured in. When flow from the funnel has stopped, empty the decanter and pour an additional decanter of water into the brewer. Place the decanter on the base plate and close lid.
9. Replace the sprayhead and funnel. Pour additional decanters of fresh, cold water into the brewer as needed until the water has no vinegar taste.
10. Place decanter on base plate and plug in the brewer. Allow the water in the tank to reach brewing temperature before using (approximately 15 minutes).
Thermal Carafe Routine Cleaning (BT model)
The carafe may be disassembled for cleaning. Rotate the lid counterclockwise to remove. Occasionally, the FlavorGard® valve should be removed and cleaned. Use a mild, non-abrasive detergent to wash the lid thoroughly, paying particular attention to the area where the FlavorGard valve is located. Lift at the edge and pull up. After rinsing, replace by aligning the tab on the FlavorGard valve with the slot inside the carafe lid and press in place. Do not use a scrub pad or other abrasive cleaning device, as this will scratch the stainless steel surface. The brew funnel and carafe are top-rack dishwasher safe. For best results, do not wash the carafe lid in the dishwasher.
To remove coffee stains from inside the thermal carafe, place a paper filter in the funnel and pour in two teaspoons of Cascade® powder dishwasher detergent into the paper filter. Slide funnel onto the rails and open brewer lid. Pour one carafe of cold water into brewer. Position carafe on base plate of brewer and close lid. When brewing cycle has stopped, remove the brew funnel and discard the filter and detergent; rinse funnel thoroughly. Allow carafe to sit for 10-15 minutes. Using a long handled, soft bristled brush, clean inside of carafe as well as the outer rim to remove any coffee stains or debris. Occasionally scrub the carafe pour lip and the area around it, including the lid, with a mild detergent and warm water. Use a soft cloth and scrub hard. When finished, pour out solution into sink and thoroughly rinse carafe and lid with clean water.
Draining your brewer
The water in your BUNN coffee brewer should be emptied whenever it is taken on a trip, shipped, stored in an unheated location with a chance of freezing, or goes unused for a extended period of time. To drain your brewer, use the following procedure:
1. Unplug the brewer. Remove the brew funnel and sprayhead from the brewer and set them aside.
2. Cool the brewer by pouring a full decanter of fresh, cold water into the top of the brewer. Place decanter on the base plate and close the lid. When water has stopped flowing from the brewer, empty the decanter. Repeat this process and set the decanter aside.
3. Grasp the back of the brewer and carefully turn it upside down over a sink. Most of the water in the tank will flow from the sprayhead tube opening. Some water may flow from the area around the top lid. Continue tipping the brewer until the flow stops.
4. Replace the sprayhead and funnel after the water has been drained.
Posted on May 29, 2011
  • 3,361 Answers
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
Mr.coffee LMX43 clean light on. will not go out
plug it out for 1 hour and plug it in back.this done so that the coffee maker circuit can reset itself.good luck.if that does not work the coffee maker needs to be taken down and clean.
Mar 04, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
My coffee pot is black inside & using vinegar does not clean it
Use a coffee pot cleaner such as Dip-IT. Walmart sells a product in the coffee maker area that is for cleaning the coffee maker. It cleans the coffee pots too.
Feb 24, 2011 | Cuisinart DTC-975 Coffee Maker
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
Coffee maker brews all but the last half cup, which vaporize the water and releases steams away for about 8 minutes. What could cause this to happen. The unit is several years old and gets daily use;...
mcdevito75 here, Your coffee maker may need cleaning as the water used to make the coffee contains impurities that clogg the coffee maker. Follow the instruction manuals instructions on cleaning your coffee maker.
Jun 19, 2010 | Zojirushi ECBC28 Coffee Maker
Cleaning
How do I clean my mr. coffee?
Jun 03, 2010 | Mr. Coffee AD4-2 Coffee Maker
Self cleaning the quisinart coffee maker
I always use a mixture of 50:50 of cold water and white vinegar to help clean the internal parts of any minerals and scaling.
Unplug the coffee maker first, then add the water/vinegar mix to the reservoir.
Place a new, clean paper filter in the basket to help catch any deposits that will be dislodged and cleaned from the coffee maker.
As far as having the coffee pot dry, there is no need for that. I do tend to wait about 15 minutes to let the cleaning mixture disolve any deposits in the main water reservoir and then I turn on the coffee maker and let it process the water/vinegar solution through it.
Once it's done, turn off the coffee maker and discard the solution in the pot. And rinse out the coffee pot/carafe with clean, fresh cold water. Remove and throw away the used paper filter element andrinse out the basket with warm water and put it back on the unit.
Now fill the coffee pot/carafe with fresh, clean water and pour that into the coffee maker's water reservoir. Put in a new, clean, paper filter and turn the unit on and run a plain pot of water. This will help to clean out any remaining residue and clear the unit of the vinegar taste and odor.
Now you're all set to start making fresh tasting coffee again. I always recommend using filtered water for the best tasting coffee, as the taste is a direct result of brewing temperature, water purity, and the coffee you use.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Cuisinart DCC-1200 Coffee Maker
My coffee maker says it needs to be cleaned. I
My coffee maker is model DCC290BK. I have no instructions, but just bought this in a Thrift Store
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee has a greasy taste
You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
Have a cup on old saw
Aug 09, 2009 | Bunn VPR Coffee Maker
Cleaning my coffee maker
can the carafe of the stainless steel coffee maker go in the dishwasher?
Mar 19, 2008 | Cuisinart DCC-1200 Coffee Maker
Bunn NHB Coffee Maker Logo
172 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
