Question about Channel Master (9537) Remote Control
Channel master cm-7000. i do not have set up instructions. my Tv is a magnavox MSD513E
2 Suggested Answers
SOURCE: code for Channel Master CM-7000
If you do the setting up using device codes scan correctly (page 25 in the user guide ) it worked with my sony bravia KDL-32L5000.
Posted on Jan 10, 2011
How to properly connect the channel Master antenna tuner to my TV so that I can connect an antenna to the tuner. I have the CM-7001. I'm connecting through the HDMI port on the tuner to the HDMI port
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Sep 03, 2014 | Channel Master CM-7001 ATSC Antenna and...
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
My Channel Master CM-7000 D2A TV Converter box is stuck with Red Light ONLY. Does not respond to any button I press. There is no picture
This is a common problem. There are several capacitors on the power supply and logic board that are bad. Replacement of these parts has restore all units that I have looked at.
On the power supply I would replace at a minimum:
C14 - 4.7ufd 50v UPW1H4R7MDD
C4 - 1ufd 50v UPW1H010MDD
C8 - 100ufd 25v UHE1E101MED
C10 - 470ufd 16v UHE1C471MPD
C12 - 1000ufd 10v UHE1A102MPD
There are 4 others in the supply that were not grossly bad.
C1 - 22ufd 400v EEU-EE2G220
C7 - 220ufd 25v UHE1E221MPD
C11 - Same as C10
C13 - Same as C10
Logic board:
E5 - 33uf 35v EEU-FM1A471
E6 - Same as E5
Part Numbers of replacement caps are Nichicon or Panasonic.
Note: Caps on the logic board are extremely hard to replace due to the internal ground plane.
Contact me if this is beyond your skills for possible repair.
Nov 06, 2011 | Digi Channel Master/tal to Analog...
I have a Channel Master cm-7000. It won't turn on. The red light is on it won't turn on with the remote or by pushing the on button. I tried unpluging it and pluging it back in and all that happens...
C11 - Same as C10
C13 - Same as C10
Logic board:
E6 - Same as E5
Sep 07, 2011 | Digi Channel Master/tal to Analog...
I have channel Master 700 by PCT that the red light will not turn to organge then to green.. It stays red, no matter what I do?
C11 - Same as C10
C13 - Same as C10
Logic board:
E6 - Same as E5
Apr 25, 2011 | Digi Channel Master/tal to Analog...
Code for Channel Master CM-7000 Digital TV converter box ? I need code number for Sony TV
Oct 26, 2010 | Channel Master (9537) Remote Control
I lost all the tv channels on channel master cm-7000 model and do not understand how to get them back?
First look at the indicator lamp on the front left side.
If it is:
off - check the power cord is plugged into a working outlet.
Amber - the unit is in standby, press the on button (left most), it should turn green
Green - the unit is in operate mode, check the antenna and cable connection.
Red - when power is applied, it will be red for up to 30 seconds. If it remains red, the unit is defective. This is a common problem due to several capacitors on the power supply and logic board that have gone bad. The unit is repairable by replacing these capacitors.
Jun 05, 2010 | Digi Channel Master/tal to Analog...
My CM7000 has a red light on, and won't boot up
Most likely bad capacitors in the power supply. I have fixed several including my own. See avsforum CECB thread for more info
Mar 30, 2010 | Digi Channel Master/tal to Analog...
I have a magnavox model msd513e.i need to know how to program my urc3021 remote.
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Magnavox TV's are: 0054, 0706, 0030, 1454, & 1254.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Feb 22, 2010 | One For All URC-3021 Remote Control
My tv won't go past channel 17
Please try this free Philips Flat Panel Television owners manuals, user guides & how to ... A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ... 13" LCD-TV PF7835 - Philips 20" LCD-TV Product Brochure ... 13MC3206 - Magnavox TV/DVD Combination ...
tv.manualsonline.com/manuals/mfg/philips/philips_flat_panel_televis... - 674k - Cached
Aug 21, 2009 | Philips Magnavox 20MS233S 20" TV
Channel Master (9537) Remote Control Logo
41 people viewed this question
Top Channel Master Televison & Video Experts
Peter Privates
Level 1 Expert
Are you a Channel Master Televison and Video Expert? Answer questions, earn points and help others
