I was trying to hook up a DVD player via the Component 1 and I also tried the Component 2, when hooked up I got a picture and perfect sound but the screen was like watching a black and white pic. It may need cleaning, is there anyway to clean up inside the AV plugs in the TV?
    Sergeant:
  • 247 Answers
I would not recommend it other than maybe a keyboard duster, the problems your are encountering sounds like cable issue symptoms. have you tried swapping out the cable.
Posted on May 29, 2011
Testimonial: "thanks for the quick reply"
  • pandehughes May 29, 2011
    I did swap out the cable, actually I hooked up my Wii to the same components and had the same thing happen, but I hooked it up to the input plug and both the DVD and Wii worked, so problem solved there, but I would still like to know what's going on with my Component 1&2 hook ups. Sorry for my non technology talk, I don't really know how to describe other than the way I have. THanks!!!
Flat screen philips tv , tuning found channels want to locate them ?
Posted on Jun 01, 2011
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
I connected via scart/component cable to my vsx-2020. i don't get any picture. the sound is ok. i connected it via en optical cable for the digital sound and rca cables for the analog sound. what shall i...
I had the same sort of problem with my DVD player. I tried another one and it worked for both video and audio so I concluded the old DVD had bitten the dust. Make sure you hook up the other DVD (that works) in the same manner as the one that doesn't work so you limit the parameters to whether the old one works or not.
Nov 03, 2010 | Pioneer DVL-909 DVD Player
I hook up my tv cable to the Component 1, and it works
make sure you are using component video red green blue cables for video and not just the yellow composite video cable not sure if this helps you but good luck
Nov 30, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Sound but no picture on TV
Try hooking your components up to the "AV1" and "AV2" jacks on the TV. I experienced this when hooking up my DVD and VCR (movies of my kids so kept it around). I hooked one to AV1 jacks and one to COMPONENT jacks and had the same result you're describing. Hope this helps.
Mar 28, 2009 | Philips Televison & Video
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Will play sound but no picture
1.check your video cable between DVD and TV.
2.in back of dvd one yellow socket only for video out others for some other purpose.
3.open tray conditon .-go to system menu on Remote -go to general set up page-video set up -and switch of .progressive -in OFF-mode.
then try it for video play back
4 if not ok replace the video decoder ic.
Nov 12, 2008 | Philips DVP642 DVD Player
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
"No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
Feb 07, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Televison & Video Logo
184 people viewed this question
Top Televison & Video Experts
Electro Med Services...
