Question about Craftsman 42" Briggs Stratton 20 hp Gas Powered Riding Lawn Tractor
B&S 20hp craftsman 46" dls3500
B&S 20hp craftsman 46" dls3500 riding mower. Starts fine, runs without dying but runs rough, cleaned carb, sparkplug, filter, almost like it is running out of gas but has 3/4 tank.
  • 3 Answers
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
Posted on Jun 08, 2013
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
ozark333
  • 396 Answers
SOURCE: I have a Craftsman mower LT1000 riding mower 17
Also, unplug the wires connected to the bottom of the float-bowl. Just wiggle the plug loose off the bottom of the bowl.
These are 12 volt powered when the ignition is on. Put your key in the ignition and turn it to ON. * DO NOT ATTEMPT TO START THE MOWER.*
With the key in the ON position, use a volt meter and test for 12 Volts
to the terminals of the plug. The Grey is Positive and the Black is Ground.
You should see 12 volts to this connection which powers the Fuel Shut-off solenoid. This solenoid shuts off fuel when you turn off your mower to prevent backfires (IMO-doesnt work!) If you dont see 12 volts, check the plug on the opposite side of your mower where the Grey and Black wires go to. We have had several of these connections fail due to corrosion (needs di-electric grease-Craftsman...are you listening?) Disconnect the plug and see which pins feed the Grey wire. Now test for 12 volts at the plug on the side that leads back up to the ignition switch. If you see 12 volts you know you have the same corrosion problem. Clean the pins, if you have it, a shot of di-electric grease so it wont happen again and reconnect. Test at the float-bowl connector now. Hopefully you will see 12 volts and are all set. If no voltage is at the ignition switch side of the connector you need to test the ignition switch. I believe most mowers will use a Red wire down to the connection we checked and follow that wire to the ignition switch. Tap the wire close to the switch and test for voltage. If you have voltage you know there is a break in the wire leading to the connector. If no voltage is present at the output of the ignition switch it may be time for a new one. You could test all the wires of the ignition switch for another wire that has 12 volts when the ignition is on and simply place a jumper between that wire and the Red feed wire for the solenoid. Of course this is a last resort but should work in a pinch. Good luck.
Posted on Sep 29, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
I have a craftsman dlt 2000 with a kohler 20hp
easiest fix... replace the carb
not a rookie fix... rebuild it
but have you checked the air filter lately ???
Aug 30, 2014 | Garden
Briggs & stratton - after warm up engine idles rough or hunts -runs fine when cold
make sure the intake is not cracked or leaking spray carb cleaner arround gasket and carb sounds like you have a hot condition vacume leak
Jul 14, 2012 | Garden
Got a Craftsman DLS3500 lawn tractor, did not come with a owner's manual, and having a problem keeping it running once the blades are engaged and/or try to put it in gear to move it. The engine dies...
well first an owner's manual is how to operate it, not repair it. you can buy small engine repair books on amazon.com and eBay.
there are several safety switches to keep the mower from hurting people. all these switches are connected to a common relay which disables the engine unless the switches are telling it AOK. there are hundreds of identical questions posted here every summer about the craftsman lawn tractors and the problem relates to a bad safety switch or the relay. you are going to have to examine each of them and do some trouble shooting
Aug 28, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
20hpcraftsman3000 smoked and died. restarted with
Sounds like a major malfunction in the carb to much fuel getting fed to the cylinder, either get a rebuild kit for that carb or buy a new one. If you are unsure about rebuilding, take it to a service center in your area.
Apr 28, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Jul 23, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Riding mower having problems starting then runs roughly
I would bet you have a fuel problem. Either the carb is clogged and dirty or needs adjustment. Try opening the screw on the bottom of the carbuerator about a half turn see if that improves it. Also check the air filter and clean it.
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 19hp riding mower wont stay running
The carb jets are partially clogged and needs to be cleaned.
Apr 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42" Briggs Stratton 20 hp Gas Powered Riding Lawn Tractor Logo
229 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
