Question about Panasonic PT-47WX51 47" Rear Projection Television
I try to ajust the green convergence on reference mark down ,and i can't move this line to left or right. how i can ajust the lamp to the righ or left. thank you
  • Panasonic Master
  • 8,457 Answers
Ur tv 100% have a problems known as a convergence picture peoblems.The tv convergence board it is dead,if any of the colors lines R,G,B mis alignments and u will not able to auto or manually to adjust any of the R,G,B colors lines to alignments any of them up.The tv convergence board must be replace like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Posted on May 30, 2011
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Looks 3d
Do not open anything until you. Go to menu on your remote find convergence and press the volume button to the right go to manual and press right again. you should see a bunch of rectangles, now you should also see a set of red cross heirs press the #2 to move cross heirs up and eight to move down numbers 4 and 6 will move left and right and 5 will place the cross heirs back to the center once you have chosen the selected section to adjust line up the magenta with the other colors using the channel and volume buttons these move the lines up down left to right adjust all lines until they are white. i do not know how to switch from magenta to green or blue but this should get you started on the right track with out having to replace anything. good luck! if you figure out how to switch from maqgent to green or blue please post it so that I may adjust mine as well tahnks
Dec 26, 2008 | JVC AV-65WP74 Rear Projection Television
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Sony kp-61v45 Blue Convergence off by 2 inches
you need to replace the convergence board its around 80 dollars
Aug 17, 2008 | Sony KP-61V45 61" Rear Projection...
Philips 60PP9202/17F.....The convergence is out of whack... was able to partially line up the red....can only move from left to right with compatiable remote...can't move up or down..Don't have the manual...
You need to replace the convergence ICs they are located on the large aluminum heat sink on the circuit board on the left. Either STK392-110 or STK392-120 are used in that chassis. And you can order them at this link and they provide free step by step instructions with pictures so you can do the repair yourself in about an hour. Heres the link. Just look for your stk numbers under the convergence IC section you will need to replace both of The ICs. If you need to know what they look like heres a pic.
http://servicemanuals.vstore.ca/a2d36f4.jpg
Mar 30, 2008 | Televison & Video
PT47WX52F Convergence problem, 3-d look, green worse
So you are able to adjust? the crosshairs move left and right up and down. you might have to get a tech to adust it in service mode.
Feb 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
TZ-55V61 Convergence
Do you still need assistance?? The convergence IC's are always
on the largest heatsinks in set......have you replaced??....T.
Aug 22, 2006 | Toshiba TZ55V61 55" Rear Projection...
Panasonic PT-47WX51 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
