Question about KitchenAid KGSA906PSS Gas Kitchen Range
Using the selfcleaning after it finished the door remained locked front digital panel was black how do i unlock the door ?
  • randy911 May 30, 2011
    ok. so more info here. we have unplugged and we have turned off the breaker. this did not solve the problem. the front panel of the stove is digital. it no longer lights up . we cannot re start the self cleaning process or turn on the oven or anything else. is there a bypass switch anywhere that we can unlock the oven door.
  • 794 Answers
Hi randy911,
After self cleaning process the oven door needs to be closed or locked for approximately an hour for it to cool down.If after the oven has cooled down and still the door is locked try these:
1. Unplug the range or shut off the circuit breaker for 5 minutes.
2. Set the self-clean cycle again and allow it to work for 15 minutes only. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
If still the same problem chances are you have a blown thermo fuse.The self cleaning gets up to 1000f degrees and it's very hot. This is a common problem with KitchenAid. You may order a replacement thermo fuse at searspartsdirect.com. Their contact number is 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Posted on May 30, 2011
  • Jemalyn Labaguis May 30, 2011
    This needs a thermo fuse replacement based on the information that was provided. Go directly to this link to order the part. Diagrams are also provided. As well as detailed instruction on how you will go through the replacement. You may contact 1-800-252-1698 for further assistance on the part.
    Hope this helps.
Where is the re-set button to program a remote door lock for my 2000 Subaru Forester?
Obtain all keys/remote controls. Remove driver's side kick panel/lower 'A' pillar trim. Connect central locking registration connectors (white) - black wire and black/blue wire Fig. 2 . Unlock the vehicle using the key. Program first key/remote control as follows: Press unlock button Fig. 1 [1], then lock button [2]. The door lock should lock and unlock in sequence confirming programming of first key/remote control. Repeat programming procedure for remaining key(s)/remote control(s). Once the last key/remote control is programmed disconnect central locking registration connectors. Check operation of all programmed keys/remote controls.
Sep 03, 2010 | 2000 Subaru Forester
Get the unlock off
Check out this tip that I wrote, it will tell you how to get into the washer manually...
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
Apr 19, 2010 | Kenmore Elite 45986 Front Load Washer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
Land rover discovery central locking.
No, likely to be caused by the actuators in the lock mechanism failing usually causing the door to remain locked. The boor door can also fail this way, as do the front side doors. Replacement requires the whole lock unit to be replaced at a cost of roughly £60 a lock, and a hours work. Helps if you have small hands. Requires a full strip down of the door and you will need the lock unit, trim clips (a few quid) and a trim removal tool (tenner). You can bodge with a flat head screwdriver, but the tool does help prevent damage to the clips & trim panel.
Dec 19, 2009 | 2003 Land Rover Discovery
Message says "unlock door", but the door is already unlocked.
redo the self clean, something got stuck... also, dont use the selfclean again, use easy off overnight, self cleaning sucks and uses lots of $$$$$$$.
Feb 13, 2009 | Kenmore 75620 / 75621 / 75622 / 75624 Gas...
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
KitchenAid KGSA906PSS Gas Kitchen Range Logo
122 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
