Question about Craftsman 20 Hp 42" Deck Lawn Tractor
My 16 hp briggs and stratton turbo cooled engine quit running while mowing. I have good spark and fuel What else could be the problem?
  • 72 Answers
SOURCE: 19 hp Twin Briggs and Stratton engine floods after a minute
Replace the float, sometimes they get saturated and look fine but are'nt. Also clean out the jets and bowl. The needle and seat may be worn as well. In other words, rebuild the carb. This time of season, after the equipment has been sitting all winter, I rebuild 25 or more carbs a week. It should cure your headaches, and solve your problem.
Posted on Jun 08, 2009
  • 376 Answers
SOURCE: what is the valve clearance on a briggs &
.003-.005 intake, .005-.007 exhaust for single cylinder OHV
Posted on Jun 14, 2009
wadembly
  • 513 Answers
SOURCE: 19.5 Briggs & Stratton dies while mowing
the engine is getting to hot or the oil level is to low check to make sure the engine is getting the air that it needs while running they have air vents in hood as well as on sides of most of those tractors or i would mow for a while & put in a cool place to cool down if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
rwvanlue
  • 486 Answers
SOURCE: Craftsman lawn mower. Briggs & Stratton 6.75
1) check plug for being carbon fouled or fuel fouled. Even though it fires, it may not be firing correctly
2) make sure you have compression 75-100 psi. since the compression release so you can pull the rope works off of the exhaust valve, you may not get anymore than that.
3) Is there water or debris in the float bowl
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 26, 2009
22 hp b/s won't stay running
check spark make sure its bright blue but sounds like a dirty carb needle valve isnt opening enough not letting enough fuel in
Jun 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Oil is fine, runs fine for about 10 minutes then bogs down and dies. Let it sit for 10 minutes it will start again and run fine for another 10 minutes. Used to be 20 minutes, then 15. The cooler the...
It could easily be an electrical issue, or not. Get a spark tester (hooks up to the spark plug). Pep boys, Autozone, and Napa all sell them for less than $10. Check for spark when the mower has quit. If no spark, most likely need to replace the ignition module. Also check the flywheel key, if it is has been sheared or even knicked, the engine will run hot.
If you still have spark when engine has failed, check the vent on the gas cap. A clogged vent will cause a vacuum to form in the tank and stall the engine.
Aug 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs stratton,16 H>P> runs smooth 'til mower is engaged.
Is the choke staying on perhaps? check spark and plug check airflow, get compression test maybe the oil/compression rings giving way... sounds like its getting hot and increasing fuel flow for some reason??? perhaps clean carb with some cleaner while running (remove air cleaner) spray directly into carby while running run at full throttle as you spray it will try and die ... relax on the spraying and see how it goes.. check air cleaner for blockages as the same time :) hope you get it working!
May 04, 2017 | Briggs & Stratton Briggs Stratton Vanguard...
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
190 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
