We have just pirchased 2 GE window units. We need to know which of the 3 places on the bottom to we knock out for a drain place for th condensation. The model number is AEW10APH1 the serial number is DV353196
    President:
  • 1,902 Answers
The back corner one, the one away from where the air comes out. The part that hangs out the window
Posted on May 29, 2011
We have purchased 2 window units, model number AEW10APH1. Where do we find the drain on the bottom for the condesation to drain from?
Hello, most window air conditioners do not have a bottum drain. The way they get rid of the condensate is by having tje fan splash it on tje condenser, since the condenser is warm it will evaporate the condensate and this cyle keeps reapeating untill the unit is turned off.
May 29, 2011 | GE Heating & Cooling
Internal unit is leaking water
Check condensate tubes - they may be blocked and need cleaning. All manufactures recommend having your furnace and air conditioner checked and cleaned on an anual basis. You can clean your condensate tubes yourself - if it is severly blocked you may have to use compressed air to unblock, but first to a combination of bleach and water. Better yet a technician will clean the condensate tubes and well as the rest of the unit so that it's running at its top efficiency
Jan 03, 2011 | Heating & Cooling
Trying to clean the drain, how do I remove the bottom front panel to get to the filter?
you do not need to prop up the washer.
the screws are easily reached, unscrew 3 along the top and bottom panels.
the bottom panel does not, should not come off, the drain is white, attached to a black hose inside, remember a bucket!
do not touch that motor! it is ungrounded and will shock you!
Sep 07, 2010 | GE WSXH208A Front Load Washer
I have a thru-wall unit that is draining out of the back and cooling just fine. My problem is the hole in which the ac goes thru. There seems to be some condensation on the bottom of the unit that drips...
you are correct the gap needs to be closed, i would suggest the double taped insulation they use on pick up truck when you put a topper on, as if you ever need to remove unit it would be easier then the expansion foam. Hope this helps Tim
Sep 04, 2010 | LG Electronic Window Air Conditioner
Kenmore 580.75151500 A/C unit smells... We've had this window unit in place for 2 years. We've cleaned the front filter and coil, but we're still getting different, peculiar smells from the A/C. Sometimes...
Hi!!
As you know, the evaporator unit (the one that the filter covers) gets a lot of condensation which is drained thru the back (outside) of the unit. That's why the unit is installed a bit tilted to the back.
The factory drain hole is too small and gets plugged up easy, some units don't even have one, the water sits for long periods of time. bacteria grows and the smell starts.
Unplugg unit from electrical outlet.
Make sure the unit is tilted back a little.
Drill two 1/4" inch drain holes in the same back bottom corner and set a bucket to collect the dirty water that will come out while cleaning it.
Get a quart of air conditioning grill cleaner (the ecol-friendly, it is purple in color) mix it on a spray bottle with water on a 1:1 ratio.
Use masking tape and some plastic to cover electrical controls in front of unit.
Following application instruccions on bottle, carefully spray on evaporator and condenser, avoiding electrical controls. Rinse with pure water, 2 qts. minimum on each grill, let it drain for about one hour.
Uncover controls and connect unit to power outlet.
Run the fan-only for about 10 min. and then the compressor.
There are more professional ways to service the unit, but performing this simple steps will keep your unit in good shape.
Don't forget to rate this post!! Good Luck!!
Jul 20, 2010 | Kenmore Heating & Cooling
Water/condensation is backing up in the bottom of the unit and overflowing into the house.
The drain in the condensate drip pan is clogged. Locate it and clean it out.
Charlie
Aug 14, 2009 | Samsung AS1293L Air Conditioner
Genie Aire PACR12-GE - Warning light flashes 3 times-No cold air
Turn the unit off, check the bottom rear of the unit and place a shallow pan under the drain outlet and remove the rubber plug to drain the condensate out of the unit then replace the plug and turn the unit back on.
Jul 26, 2009 | Genie Aire PACR12 Air Conditioner
True cooler td 65 24. what is holding the sled in place
I think you are referring to the condensing unit that the compressor sits on. Look on the rite side of the unit near the bottom. There you should find 1 3/8" screw that runs through the side of the unit into the "sled" thus holding it in place.
May 03, 2009 | True TD-65-24 Commercial Refrigerator
GE UNIT - AC/HEAT PUMP
Hello Cheryl, what they are talking about is a drain. As air conditioners run they collect moisture from the air on the evap(in cooling mode) or condenser ( in heat mode). This moisture will run off the part and flow into the tray. In the cooling mode, the moisture is slung onto the condenser to help cool it down, thus be more effective. I always recommend once a year remove the unit and clean all the coils and oil the fan motor. Household oil will work for this. During this cleaning find and clean out the drain. If it gets clogged that water can run back into the home. The PC pipe is sometimes attached to the unit to direct the water to a designated place. These units are common in hotels and they use the pipe to keep the water from dripping on the guest as they walk under the windows. Hope this helps.
Jul 26, 2008 | GE Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
