Question about Kenmore Front Load Washer
9 minutes into the express wash cycle, the washer stopped and is now flashing "F" the "21"
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Posted on May 29, 2011
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
During the cycle, it has stopped and the screen is flashing F- 21, what does that mean? The door is locked and when I do get the door open, water spills out. What do I do?
The drain cycle only runs for 8 minutes. F-21 is a blocked drain tube. Open the panel in the front bottom and locate the drain tube (front right) Disconnect it and you will find a little collection area in the tube as it first comes out of the washers tub. Clean it out and try resetting it to drain then all should be fine. I always find coins and other stuff like tissues blocking the flow.
Jan 20, 2011 | Kenmore HE2 Plus Front Load Washer
\\\my washer flashes a F 21 and doesn't open. I washed my son's comforter the other day and the machine stopped and flashed a F 21 and would not open. when I finally kept pushing the unlock button a...
Your blanket probably caused an out of balance on the tub which caused the washer to stop in the middle of the cycle. The lock switch is a time delayed switch. Requires several minutes before it is activated to release. When washing single items you need to add another clothing item of approximately the same weight to create a balance during spin.
Dec 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Start a normal load then it stops and flashes f 21
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. after 10 minutes plug in and retry.
4. if this does not work you need service.
Apr 27, 2010 | Maytag EPIC MFW9700S Front Load Washer
Wont stop flashing time on express cycle
unplug it for 40 minutes to reset the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 08, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washer stops and must be restarted flashes F51
there is a updated wiring harness and sensor on the the bottom of this tub on the motor. It needs replaced
Nov 13, 2008 | Kenmore 22422 Top Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Front Load Washer Logo
138 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
