Question about Kenmore 22422 Top Load Washer
Kenmore 70 washer just stoped while full of water. seems to have no power but outlet has power coming from it. first how to drain second how to fix
  • Kenmore Master
  • 3,361 Answers
Replace the lid switch and everything will resume normally.
Posted on May 29, 2011
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
My 22662100 kenmore washer does not completely drain and clothes remian to wet.
if the pump isnt bad, there is a sensor mounted in the back o of the unit that controls draining. It is near the water outlets and have wire connectors. Part.com or appliance parts.com to find replacement
Apr 20, 2017 | Kenmore Sears Washing Machine Replacement...
My whirlpool washer seems to be letting water back flow from the drain line.
sounds like the drain line is too low it needs to be higher than the water level when running a full load...you can check this buy filling with water and stoping the cycle and see where the water stops draining im sure it will stop at the level of your drain line in the back of the washer. the drain line in the back of your washer should come out of the bottom of the washer and then go up to a drain pipe..if its lower than the full water level of the washer then gravity will take over and drain the water... i hope this helps
Sep 09, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Kenmore 70 series will not drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
I'm assuming that the washer will Agitate and Spin but will not drain.
Following is a description of how to remove the cabinet and pump on top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134
Be aware that when you remove the hoses from the pump, any water in them will come out so you should have a bucket set to catch the water.
Check the hoses leading to and from the pump for any obstructions.
Check the shaft on the pump to verify that it will turn without any excessive side to side movement.
Try to look into the pump to see if anything is blocking the inlet and outlet areas.
If the washer will NEITHER drain nor spin, the problem is likely in either the timer, Lid Switch or transmission.
Re-post a question if that is the case with the full model number.
Nov 29, 2009 | Kenmore Washing Machines
Kenmore 70 washer will not spin in some washing modes
Has this Washer got a drain water filter ? if so check it first. also some washers have a 'delicates' program which leaves water in the drum to stop creasing, check you manual.
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore Series 70 Washing Machine - won't drain water
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Feb 15, 2008 | Washing Machines
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
