Question about GE Heating & Cooling
We have purchased 2 window units, model number AEW10APH1. Where do we find the drain on the bottom for the condesation to drain from?
    Genius:
  • 1,033 Answers
Hello, most window air conditioners do not have a bottum drain. The way they get rid of the condensate is by having tje fan splash it on tje condenser, since the condenser is warm it will evaporate the condensate and this cyle keeps reapeating untill the unit is turned off.
Posted on May 30, 2011
Frigidaire model FFRE1033SI window airconditioner tilt problem.
Water going outside is the important part. The hole is not necessarily the drain, the angle at most is an eyesore!
Aug 19, 2017 | Frigidaire Heating & Cooling
I have a frigidarie window air conditioner with drain hole in the bottom that leaks is there a drain hose and hose adaptor that can be purchased if so where
If you cant do any better, cut a piece of plastic or flashing material and insert it under the ac so that the dripping water will fall on it and away from the building. If you make it long enough you can insert it under the unit in such a manner as to pinch it and hold it in place. You can bend it to suit. I have a number of houses with window units. The first thing I do when I get a replacement unit is pull the cover and drill a hole or two, 3/8 to 1/2. The largest I can drill and not touch the coils.
May 06, 2012 | Heating & Cooling
There is no drain hole on this unit..if there is i cant find it...then the condesation runs down my walls...what should i do to find the drain
Window units usually drain through a notch behind the condenser or a hole in the bottom. If the unit is leaking chances are that it is not properly leveled. The unit should slope slightly downwards towards the rear of the unit. Water in the condenser pan is normal- it's an efficiency thing. If the unit is properly leveled and still leaks into the room then there may be dirt clogging the evaporator pan- refer to a service manual on how to take the unit from the case and properly clean it.
Sep 25, 2011 | Whirlpool Designer ACQ088MR Wall/Window...
My amana window ac is blowing condesation out the vents. it is still cooling..is this a problem
There is a condensation drain on the unit that is probably plugged. It is natural for air conditioning units to produce condensation as the evaporator coil (the coil/fins that make the air cold as a fan blows air across it ) is much colder than the outside air temperature ( usually between 38 and 55 degrees depending on the unit ). There is a basin or tray at the bottom of the unit that catches the condensation as it drips off the evaporator coil, and there is a drain that allows the water to drain form the unit. If this becomes plugged the water will build up and eventually drip out of the vents of the unit. http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-circuit-and-cycle-diagram.html
In the image, air is blown across the coil in the bottom left section of the picture ( this is the "cold' coil). Condensation can form on this.
Jul 29, 2011 | Amana Quiet Zone 12M12TA Air Conditioner
Why is there no drain hole for condesation to drip out?
Some of the Friedrich units will drip out in the back of the unit. There may be just a small bend in the base of the unit allowing a certain amount of draining just behind the rear coil. Most units require some water to remain in the back of the unit to help cool the unit off. This is why tilting in the window is important. Be sure not to tilt it too much or too much water will drain, causing the unit to overheat. Be sure to tilt it enough to where the water can drain properly or the water may drain in the house, down the wall.
Jun 20, 2011 | Friedrich CP18F30 18000 BTU ThruWallWindow...
How can i test if a standard built in condesate
Switch main power off.
Disconnect drain connection
Pour some water trough the drain in the unit.
Put a bucket under the drain.
Switch on the main power supply.
Put the airco on in cooling mode.
If the pump is working, water comes out.
Sep 14, 2009 | Heating & Cooling
Water leak
There is a problem with the condesation drain being plugged in the bottom of the unit. The water is supposed to drain onto a "condensation pan" under the unit where it typically evaporates without causing problems.
I believe that the solution was to pour bleech in the drain...
Aug 01, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dosent drain
well lets work with it becouse that the one you have..first let me tell you dont make that hole becouse the water that remaing in the tray is use to cool down the condenser and beleve me its a good idea..its not supouse to condese more water thant he can evaporate..but try to screw a littel bit more the two screw in the back of the cabinet to down the cabinet 10 degrees more to see if that help you...good luck
Aug 03, 2006 | Haier HWF05XC5 Air Conditioner
Heating & Cooling Logo
234 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
