Question about Smeg Classici SCP160X Oven
After running the oven through the Pyrolysis automatic cleaning programme the safety lock (which engages when the cleaning is in process) will not open even when the power is turned off.This means the ovn door is locked.
5 Suggested Answers
  • 18 Answers
SOURCE: glue oven safety glass
You need a high temperature silicone adhesive specific for the job. No point using epoxies, they will not give you a long term solution and you will waste time and money.
This company makes a glass oven door repair kit that will do the job for you.
Posted on Feb 22, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Smeg SA130P
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Dec 14, 2010
aviral_srms
  • 1216 Answers
SOURCE: SMEG SE210X-5 Switched off mains,
You need a magnetron replacement if the oven is on and still not heating.
Posted on Jun 25, 2011
SOURCE: Can't get the GE P7 door lock engaged in order to
how to disconnect oven cleaner on kenmore electrict stove
Posted on Oct 23, 2011
How can I open a stuck oven door after running the cleaning programme?
Did you release the lock on top of oven door? Oven would not start cleaning until this lock is in place.
Mar 23, 2016 | Ovens
Neff B4562
Engineer is a solution.
The other solution is;
Switch 3 times between rotisserie and pyrolysis or bread baking setting and pyrolysis.
As acknowledgement the displays are actuated.
At each change of operating modes switch immediately stops the current test step and the next step of the test enabled. The oven light should according to the mode ON or OFF; that is, at pyrolysis OFF otherwise ON.
Jul 01, 2012 | Ovens
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    How do you clean a self-cleaning gas oven?
    If it's one with pyrolytic oven coatings then you empty the oven and turn the oven to maximum for about three hours.
    The linings will get hot enough to burn deposits to a light ash residue which you can then wipe off with a damp cloth when the oven has cooled down.
    Some modern ovens have a self-cleaning setting on one of the controls. All it does is to automate the process and to lock the oven door until the cycle has completed.
    Note that you will smell the fumes as the oven self-cleans and they can set off any smoke alarms you have. Also, if the oven is really filthy and thickly caked in grease then the pyrolysis will not be fully effective. Note that oven shelves and other metal fittings and also door glass are not pyrolytic and any deposits will get baked on, so clean those separately first. Really stubborn deposits will come off using a caustic-soda based cleaners, but you must wear suitable protective gloves, glasses and clothing and exercise extreme care when using them as caustic soda burns are far, far, worse than acid burns.
    Jul 09, 2011 | Whirlpool SB160PEE Gas Single Oven
    Hi lost the manual..need to start self cleaning
    An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
    Step 1 - Setting the Self Cleaning Mode
    Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
    Step 2 - Cleaning Cycle
    Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
    Step 3 - Automatic Door Lock
    When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
    Step 4 - Removing Residual Ashes
    Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
    Hope this helpout
    May 17, 2011 | Ovens
    I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
    you might try the following, although it is the instructions for an old model, it may be relevant;
    "The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
    A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
    I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
    Nov 18, 2009 | Ovens
    I started to clean the oven and just befor the lock locked, I checked inside. The oven door now is stuck and the lock engaged. What can I do?
    Hi
    Try switching the power off at the wall switch and then back on again. It may be that you also have to wait for the oven to go through the clean cycle as it is safety locked during auto clean.
    Nov 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Kitchenaid superba oven stovetop oven door will not open after se
    When the oven goes into clean mode the door is automatically locked as a safety feature. I would put it back into clean mode again, let it clean for a while and then hopefully when it cools down the door will open. good luck .
    Mar 20, 2009 | Ovens
    Oven cleaning bosch oven
    self cleaning is sometimes a cycle called PYRO clean / look for the setting with a really high temp. self cleaning is a programmes require a massive amount of heat and will smoke a lot when on , so dont be alarmed! most oven when on self cleaning mode will automaticly lock the door due to the high heat involved in the process. so remember to remove pans etc. from inside.
    Feb 10, 2008 | Ovens
    Smeg Classici SCP160X Oven Logo
    46 people viewed this question
    Top Smeg Ovens Experts
    ashburton
    Hjalmer Lamminen
    Hjalmer Lamminen
    Jason Harris
    Jason Harris
    Are you a Smeg Oven Expert? Answer questions, earn points and help others
