HDD problems Test status #2-07 FAIL From COMPAQ Presario 2200
    Scholar:
  • 81 Answers
If it still boots try pushing the f8 button during boot until you go into the black screen and see the safe mode and click on safe mode command prompt. then it will ask you which win volume click 1 then your password if you have 1. then you will come to C:\WINDOWS> this is where you type in chkdsk /r
Posted on May 30, 2011
Presario 2200 hdd not being detected
This is not good, remove the hard drive and reseat it back in place, sometimes that is enough to get it going, if no change! the hardware may be open and if that has been determined you will need a new hard drive.
Mar 28, 2012 | HP Compaq Presario 2200 Notebook
Manuel for compaq presario 2200 series 3297
Hi Carol,
Here's the manual in pdf.
Hope this helps.Thanks!
Please rate this answer.
Dec 14, 2011 | HP Compaq Presario 2200 Notebook
My Compaq Presario 2200 powers on ("on" led, drive
1) put the laptop on a bed or a similar surface to close the air openings below
2) wait some time (15-30 min or 1hour) and let it get warm enough
3) restart.
it worked for mine. hope it works for you too.. the laptop seems stable and does not give any more beeps (for now).. good luck !
Jan 02, 2011 | HP Compaq Presario 2200 Notebook
I have a hp computer i formated my c and d drive because they where both messed up and order the recovery disk, before that i installed xp onto the pc after that day i removed xp and i got this problem...
If you can install an operating system (any operating system at all, XP, Vista, Linux, ...) the message from your BIOS is plain weired.
Other than that, you will probably need to replace the harddrive. Please let us know in case you need further help with that.
Find HP's support link for your machine attached.
Compaq Presario C502US Notebook PC
Jul 12, 2017 | HP Compaq Presario C502US Notebook
Installing XP SP2 on Compaq Presario R4000, after
Run a HDD Test
Restart Computer -> Immediately keep tapping F10 Key which is on 1st row of Keyboard
Go to diagnostics with your arrow keys
Go to Primary HDD Test -> Press Enter ->
See the Test result
If Fail then Contact HP for Replacement of HDD or Service
Jun 01, 2010 | HP Compaq Presario R4000 Notebook
Hi! i got a mobile presario compaq presario
What kind of device are you trying to connect. If it is a hign amp device like old external HDD, it could cause he issue. In such cased connect both the USB pins provided to facilitate more current flow.
Also check the status of USB from device management. No warning symbol should be displayed.
Please come abck and rate for my solution if it turned to be helpful for you.
Thnx :)
Mar 22, 2010 | Compaq Presario C700T Notebook
I have a problem geting my recovery disc to work in my compaq presario 2200 laptop, as i have just installed a new harddrive iam getting a PXE-E61: Media test failure and PXE-M0F Exiting PXE-ROM. ldygolfer
You need to change the boot order in the bios.
When you start the computer screen should prompt you at the bottom with something like:
F2 or F10 to enter setup.
Once you're in the bios, change the boot order to cd / dvd first.
Right now it's trying to boot through the network, that's why you're getting that message.
Let me know if you need any more help.
Best of Luck!
Feb 24, 2009 | HP Compaq Presario 2200 Notebook
Compaq presario 2200 screen stay dark
sounds like the inverter has gone, the only way to test this is to remove the laptop lid, remove the bezel (front plastic cover) please take care not to crack or splitt the plastics, then get an electical tester and test the inverter coil to make sure a current runs through it, if it doesn't its the coil, if it does you need a new inverter, the coil is located under the plastic sheath
good luck
Nov 14, 2008 | HP Compaq Presario 2200 Notebook
Hard drive failure compaq presario 2200
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Nov 05, 2008 | HP Compaq Presario 2200 Notebook
Presario 2200 won't boot up
Hello
your hard driver is broken or it can be your motherboard sata controller.
sorry
replace your hard drive and run a restore. you can get your restore cds from HP.
check if you have warranty left. then you can go to nearest hp reseller and get your motherboard or hard drive changed for free.
good luck
Aug 10, 2008 | HP Compaq Presario 2200 Notebook
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
