Question about John Deere 23HP VTwin Dual Hydrostatic 48" ZeroTurn Radius Mower
Where is the oil plug and filter on a John Deere Z225?
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
SOURCE: John Deere will not start.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Posted on May 08, 2010
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
SOURCE: hydraulic reverser problem with John Deere 1010
ineed to find a hydraulic reverser for a 300D john deere backhoe
Posted on Nov 23, 2010
SOURCE: John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Posted on Apr 15, 2011
I can't locate the oil filter on this 18.5 Briggs motor
Look no further my friend, because your model doesn't have an oil filter. I have verified that through YouTube videos.
May 21, 2016 | John Deere EZtrak Z225 Zero-Turn Riding...
I need a wiring diagram for a John Deere Z225
Here is the link for john deere z225 zero turn wiring diagram
I hope this helps you.
https://images.search.yahoo.com/yhs/search;_ylt=AwrTccx4EqNVkAQAphwnnIlQ;_ylu=X3oDMTEzbHNxNnYwBGNvbG8DZ3ExBHBvcwMxBHZ0aWQDRkZVSUMwXzEEc2VjA3Nj?p=Wiring+Diagram+For+a+John+Deere+Z225+Zero&fr=yhs-mozilla-002&hspart=mozilla&hsimp=yhs-002
Jul 13, 2015 | John Deere EZtrak Z225 Zero-Turn Riding...
I have a John Deere Z225 zero turn engine cranks but will not fire spark plug wet with fuel
as plug wet, either flooded, or not sparking, remove plug connect top lead and touch plug to metal, see if it sparks when turned over, if it does, with a good spark, flooding, check choke, if weak spark, check adjustment of points.
Jul 29, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
I need a wiring Diagram for a John Deere Z225 Mower.
Call john deere customer support they will supply it to you
Jan 11, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
Manual for a z225 john deere zero turn
my z225 right rear wheel feeling like it locking up about every 20 feet
Oct 03, 2012 | John Deere EZtrak Z225 Zero-Turn Riding...
Free online John Deere Z225 repair manual
You can find your manual on amazon... take a look here Amazon com John Deere Z225 manual. I hope this was helpful. cheers
Jul 08, 2012 | Garden
John Deere 23HP VTwin Dual Hydrostatic 48" ZeroTurn Radius Mower Logo
169 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
