Question about Cameras
Shutter gets stuck samsung - Cameras
  • 104 Answers
Need to get it to a repair tech and get it serviced. Could be just dirt and dust that's causing the shutters to jam.
G
Posted on May 29, 2011
Samsung L77 shutter stuck
Something is loose, worn or broken in the shutter mechanism. Repairing these is a lot of work. If you have photos you want to save to another device, see if the camera will permit it even with the shutter fault. It may be a better use of your money to transfer the SD card to a different camera and hope you can upload any photos through the other camera than to repair this one. (If the new camera tells you to reformat the card, do not do so if you are trying to recover any photos from it. Once you have recovered the photos, you can let the new camera reformat the card.)
Jul 15, 2017 | Samsung L77 Digital Camera
My samsung s760 has ahorizontal lines when you shout in a day time but if you shout it it evening the picture is ok.eventhough i put off the flash in day time it is the same result.what can i do?please...
Mary,First check to ensure that your camera is in automatic mode, and not in one of its manual modes. For example, shooting in a night scene mode in daylight could cause these symptoms. But if you are in auto, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 11, 2011 | Samsung S760 Digital Camera
My samsung BL103 camera takes good pics inside but ot outside. how do i fix
First make sure that you are in "Automatic" mode, and not in one of the camera's othe manual modes which may keep the shutter open for an extended period. But if you are indeed in auto mode, and it's still doing this, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 09, 2011 | Samsung BL103 Digital Camera
Screen is black and pictures come out black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 30, 2011 | Samsung BL103 Digital Camera
It is just a black screen before and after i take a picture
Have you tried downloading your photos to a computer, and are they also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 19, 2011 | Samsung BL103 Digital Camera
SAMSUNG S1070 - When I take pictures, white lines appear on them. They don't appear on the screen when I am not taking a picture, and they do appear when I transfer them to my computer. I have tried...
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
May 29, 2011 | Samsung S1070 Digital Camera
Outside picture are white
Make sure the ISO is set to the lowest number or even to "auto ISO". The best way to avoid these lighting problems is to adjust your aperture settings, your shutter speed and your film speed when shooting. Additional details about thus sibject could find in the Samsung_S500_Owners_Manual in section about Settings & Mode.
Its possible that you are interesnting to check other
information, so visit this two sites Fix-Overexposed and this other take-better-photos-in-5-easy-steps.
Finally, remote but possible, could be t
he symptoms of a stuck or "sticky" shutter, this are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Hope helps.
Apr 29, 2011 | Samsung Digimax S500 Digital Camera
Got a samsung s500 as a gift from a friend.haven't been using the camera for a while and now camera screen is all black.help!
Sounds like your camera's shutter is stuck in the closed position. Some owners have reported success in freeing the shutter by firmly tapping the bottom of the camera against a hard surface, but this "fix" can cause even worse problems if your tap is too forceful. You can also try powering the camera on while you hold the shutter release button, but chances are that the camera will need professional repair. Suggest that you take it to a Samsung dealer (NOT the camera shop at a chain store) and also check the Samsung web site for repair procedures and prices. Be sure to get a firm price before you commit to anything, though. The price of a fix can approach the cost of a new camera, and repairs typically only carry a 30-day warranty.
Bill B
Mar 30, 2010 | Samsung Digimax S500 Digital Camera
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
