Question about Toro Power Lawn Mower
Where can I find a toro model 184986 12A566N711 lawn mower manual. Hopefully free!
  • 109 Answers
SOURCE: Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Posted on Apr 26, 2009
  • 86 Answers
SOURCE: I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
Posted on May 16, 2009
  • 148 Answers
SOURCE: Need Parts/Service Manual for Toro HMR1600 mower.
Go to www.managemyhome.com and put in your model # for the manual (You can download to your computer). Also try www.searspartsdirect.com and put in you model # and you should be able to see all the parts for your mower.
Posted on May 19, 2009
  • 32 Answers
SOURCE: Toro Lawn Mower model 20016
it isn't the spark plug if it wont turn over. maybe your battery is dead.
Posted on Jun 12, 2009
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Posted on Aug 02, 2009
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
How to find toro manual
You didn't indicate what model you have or what type of power lawn mower but here is toro's link to manuals
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225
Aug 03, 2010 | Toro Garden
Need the engine model number for toro mower model 2006,serial 270001124
I too was looking for the engine model number and serial number for my Toro mower to submit a claim for a class action suit. I could only find the "Mower" model and serial number. I found a guide to locate the engine information in the "Engine Service Manual" for my mower.To get the "Engine Service Manual", I went to Toro's website https://lookup3.toro.com/request/request.cfm and entered the "Mower" Model # and Serial Number. That brought me to a speific page for my mower with several manuals listed, including he "Engine Service Manual" which could be downloaded for free. The information for locating the Engine Model and Serial Number was found on the first page of the Preface. Here is a sample link for my mower Engine Manual https://lookup3.toro.com/request/filechek.cfm?Lang=EN&PubNum=492-4202&PubID=6924&Cust=anonymous_user&xCaller=Toro&PubType=9
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
May 16, 2009 | Toro Garden
I cant figure out how to hook up the tiller on my toro wheelhorse i dont know if i goes on the front or the back
Go to www.toro.com then customer care, then manuals and parts then type in model no. hopefully the owners manual will show how.
Mar 26, 2009 | Toro Lawn Mower With Toro Power Tools
Hook up priming ball
go to toro.com customer care, manuals and parts, type in model no. then parts book. Hopefully it will show hookup.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Power Lawn Mower Logo
56 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
