Question about Philips GoGear HDD6330 MP3 Player
Device will not turn off after disconnecting from the computer.
    Master:
  • 623 Answers
Take batt off
make and model
Posted on Aug 16, 2008
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Tip
Internet connection disconnects
If your ethernet card or wifi adapter disconnects when the computer goes into sleep mode, and the only way out is to restart the system, try this:
Open the Device Manager, under the Properties, Power Management tab for your ethernet card or wireless adapter, deselect the box that reads "Allow the computer to turn off this device to save power".
If other devices are sketchy as to how long they'll stay active, try the same trick:
Open the Device Manager, open every USB Root Hub, and under the Properties, Power Management tab, deselect the box that reads "Allow the computer to turn off this device to save power".
on May 29, 2015 | Computers & Internet
Tip
How to troubleshoot an electrical brownout (computers)
<p>Modem router and switches <br /> <p>1. Plug the device into the outlet and see all the lights. Determine if they are all about how they should turn. <br /> <p><br /> <p>2. Disconnect the device from the device and allow to rest for five to 10 minutes you can Sun <br /> <p><br /> <p>3. Turn off the lights of the device into an outlet and a view of the screen to see where we are going. When you're gone, then the Brownout the unit is damaged and needs replacement. <br /> <p><br /> <p>Computer <br /> <p>1. Disconnect the computer from the electrical outlet and turn it so your back is turned. <br /> <p><br /> <p>2. Locate the AC adapter to the top of the PC, the rear fan. Near the fan and see if a burning smell. <br /> <p><br /> <p>3. Connect the power cable from the PC and turn on the computer. Hear the sound of the computer. If you do not hear and determine that there is a smell of burnt food, replace the power supply. <br /> <p><br /> <p>4. Open programs and working on the computer. Look to see that the freezing tissue damage your computer or network restart. <br /> <p><br /> <p>5. Listen to the fans to operate. If not the fan or the hard disc, that harm could be caused by a voltage drop. <br /> <p><br /> <p>6. Open your Internet browser and try online. If your computer is not connected to the Internet, and you're using a wired connection, unplug your computer and check the NIC light to see when it flashes. A light no flashing is an indication of a failed network card. Check the lights on the modem, router, switch and hub. If all lights are working, but the computer will not connect to the Internet, this means that the board brownouts wireless network or affected. You must replace the device failed. <br />
on Jun 22, 2011 | Computers & Internet
New keyboard does not work
To connect or to disconnect the keyboard to a PS/2 port, follow these steps:
Shut down the computer.
Plug your device into the correct port. Make sure that the plug is pushed securely into the connector on the computer.
Restart the computer. Microsoft Windows detects the change, and then installs the drivers on the new port automatically.
If the issue continues to occur, try connecting the keyboard to a different computer. If the keyboard functions correctly on a different computer, the port to which the keyboard was connected on the original computer may be damaged. If this is the case, contact your computer manufacturer to inquire about how to repair or replace the damaged port.
If the keyboard does not function correctly on another computer, the keyboard may be defective. If this is the case, and the warranty on the keyboard is still valid, you can exchange the defective keyboard for a new keyboard.
If the keyboard works on another computer, go to Step 2.
Step 2: Download and install the latest keyboard software
Step 3: Manually reinstall the drivers
To remove and then reinstall the drivers, follow these steps:
Disconnect the device from the computer.
Turn off the power for the device, if the device has a separate power supply.
Open Device Manager. To do this, use one of the following methods:
In Windows Vista or Windows 7, click Start, type device in the Start Search box, and then click Device Manager in the Programs list. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In Windows XP, click Start, click Run, type devmgmt.msc, and then click OK.
Double-click Keyboard, right-click the keyboard that you use, and then click Uninstall.
If your device is not listed, this means that the device was removed automatically when you disconnected the device. Go to the next step.
First, turn on the device, if you have to, and then plug the device into the computer. Your computer detects the device and then reinstalls the drivers for the device.
Jun 04, 2012 | Acer Computers & Internet
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
Blank/black screen when i turn on the laptop
Please try the basic troubleshooting steps to resolved the issue:
- Disconnect all external device (example: USB Flash Drive, Printer, external hard drive, etc.) - Turn off the computer by pressing and holding the power button until all lights turned off. - Disconnect the ac adapter from your computer. - Remove the battery, wait for 10 seconds, then connect the battery back. - Plug in the ac adapter. - Turn on the computer.
Hope that helps.
Apr 17, 2011 | Dell Vostro 1510 Laptop
In my win 7 card reader doesnt support .. Why?
Try installing the device using Vista drivers, You need to use compactibility mode to get it to work though or :
1) Disconnected Media Card Reader and reconnected it. I wanted Windows to automatically detect the hardware change. Details of the first step:
a) Turned off Windows.
b) Disconnected Media Card Reader.
c) Turned on Windows.
d) Turned off Windows.
e) Connected Media Card Reader.
f) Turned on Windows.
2) Disabled and re-enabled the controllers.
a) Opened Device Manager.
b) Expanded IDE ATA/ATAPI controllers.
c) Uninstalled each item one by one.
d) Restarted the computer.
3) After the computer started, Windows reinstalled all the controllers
Jan 20, 2011 | Dynex External USB 2.0 Multiformat Memory...
I canot turn on the ipod.
First, try connecting the iPod to your computer and try turning it ON.
If your iPod turns on when connected to the computer via USB cable, then the problem could be the battery or there's a loose wire connection.
But if the device won't turn on when either connected or disconnected from the computer, it could be the power button or the firmware of your device.
Unfortunately, for these problems, you need to contact the manufacturer and have them repair your device for you.
Feb 25, 2010 | Apple iPod nano
Music not synchronized
Try going to the actual file the music is in on your computer, then right click Send To sansa 250. If that doesn't work look on the options menu for USB mode and change it, that works on my 280.
Oct 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Disconnection problems
well i guess it under garatee my sugestion is to take it back to wear ver you got it from
Jan 28, 2008 | iRiver S10 2 GB MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
13 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
