Question about Emerson Quiet Kool 10NW16K Air Conditioner
.ALL NEWI HAVE A 11000
  • 413 Answers
The fan blade sounds like its hitting the shroud for some reason. Sounds like you need to take it out of the case and clean the rear coil. The rear coil gets all stopped up with dirt, etc. You can wash it out but if you do be very careful not to get the motor wet. Unplug it when you are cleaning it out and let it dry out for an hour or so before you plug it back up.
Posted on May 30, 2011
I am looking for a replacement filter for an Emerson Quiet Kool 5200 btu late 80's window a/c The filter is not foam not mesh.Also where can I find the model number on this unit. Thank you!
You should be able to custom cut a foam or fiberglass filter to replace the original one. Measure the size and go to a hardware store or use the original one to match.
Apr 30, 2017 | Emerson Heating & Cooling
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
I bought an Emerson Quit Kool Model # AJ581803, and serial # AJ581803 0287. It says 24000 BTU/23500 with 16000/13400 heating BTU. I was wondering if you could help me with the age of this unit? It has a...
I entered your data-- Apparently it is 'QUET' cool-- insntead of Quit cool--:-)
THe few hits that came back, agree that this is a VERY OLF-- but also VERY GOOD Thru the wall AC unit!
So-- let's figure out how to get a more modern cord plug on it safely--
What tools do you have to make the cord swap?
and do you have a new cord that you can exchange it with?
Or here is another idea-- How about changing your receptacle in the Electrical box,. to match the older style cord?
Would you be able to locate the older style receptacle-- is that an easier option, or not?
Get back with me-- I want to help you
Mack B
Aug 08, 2011 | Heating & Cooling
I have a Emerson Quiet Kool Model # 12JW42K that is 13 years old. It doesn't seem to cool the apt. anymore. I assume that it would be smarter to get a new "energy saving" unit than invest in...
I know that a Island Air units come in all shapes and sizes and they make a ton of different units. They are made in new york thats who I would use. I would definitly go with the 12,000 btu unit 500 square feet needs 12,000 btus 10,000 is under sized. 500 square feet divided by 500 = 1 ton of cooling. let me know if I can further assist.
http://www.islandaire.com/
Jul 23, 2011 | Heating & Cooling
I need the specs on this specific A/C. I dont have a manual & need to know how many BTU's; Energy star rating.
You surely can see all that right in plain site,
on top of the evaporator box on all window units
Look thru air vents on front,left side
or remove front cover & look
Jul 18, 2011 | Emerson Quiet Kool 12GJ14 Air Conditioner
Lately at certain times while running for days it makes a clanking noise(sounds like the fan) I spray water through the back of it with a water bottle and after 20 min the sound slowly go's away.It is...
This is normal, the noise you here is most likely ice build up on the condenser coils. when the outside temperature is under around 15c ice will build up on the condenser coils it then falls and hits the fan blades. this will also happen if the unit has been running for a while. there is no need to spay water into the unit as this can cause damage to the electrical components.
Jul 12, 2011 | Emerson Quiet Kool 12JW42K Air Conditioner
12,000 btu emerson quiet kool 220/230 about 9 years old, need to know $$ per hour to run with total kw/h cost $0.30 (this includes all taxes and fees). Sorry can't provide wattage or amps (no manual...
If your device doesn't list wattage, but it does list amps, then just multiply the amps times the voltage to get the watts. For example:
amps x volts = watts x .30 if you dont have any information you are sol.
Jul 06, 2011 | Emerson Quiet Kool 10NW16K Air Conditioner
I have emerson quiet kool but the fan with not turn it keep on making a miiiiiiiiii sound
Hi, what has happened here is you have lost the blower motor to the unit. Anytime a motor will not turn and makes noise as it is trying to start, the windings are about gone, and /or the bearings are froze up. I know this is a Emerson, but I don't know the model of this unit, or if it is a window/wall unit or larger. If it is a wall type unit, it will have a dual shaft motor in it for the blower and condenser fan. It would not be worth the cost to have this motor replaced unless it is a Emerson central heating and air system. It is possible that this unit has a run capacitor on it that may have failed, but when this happens the motor will just stop and not make any noise at all. The motor needs to be changed out if its a central unit, and if you want to get an estimate to change it out if its a window or wall unit you can, but it may cost you more then the unit is worth, just to be honest from my years in this business. Please keep me posted on this and what you decide to do. Please don't forget to rate this post as I know you will be kind. I wish I had better news for you, but this happens and there is not much you can do your self. I wish you the best.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Sep 25, 2010 | Emerson Heating & Cooling
BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
Emerson Quiet Kool A/C Filter
If you know where to find a filter for a Emerson Quiet Kool--Model # 18DD4H-EE
Serial # 21A 927552 Please let me know
beverleyed@yahoo.com
Thanks
Ed Beverley
Jun 07, 2008 | Emerson Quiet Kool 10GV13 Air Conditioner
Emerson Quiet Kool 10NW16K Air Conditioner Logo
94 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
