Question about Samsung Refrigerators
Will not Defrost, the Defrost heater is deffective. can the heater be replaced without replacing evaporator ? Model # RS2577SW/xaa
  • cyrus_ellen May 29, 2011
    I I came to the same conclusion myself by looking at the diagram.. Is there and Alternate, like adding a foil heater in place of it?? Your answer was vauge.. I wanted expert advise which I PAID for. Please advised.
  • cyrus_ellen May 30, 2011
    Thanks!!!
  • 4,070 Answers
It's hard to tell from the diagrams I could find but if the heater is intertwined in the evaporator you do have to replace the evaporator.
Posted on May 29, 2011
  • Charles T Nevin
    Charles T Nevin May 30, 2011
    If It were mine I would get a replacement heater of the type that fits along the bottom and part way up the side. It's a flexible type heater. The wiring would have to be adapted but it will work. There is no set procedure for this. It is 100% Do It Yourself.
I have a side by side jennair refrig freezer. The bottom is cold on both but not on top any suggestions
You have a defrost problem. There are only three components that make up the defrost system in a refrigerator, the defrost heater, the defrost thermostat and the defrost control board or defrost timer. The best and easiest way to check the defrost system is: Remove the evaporator cover (freezer section back wall) and check the defrost heater and defrost thermostat for continuity with an ohmmeter. Check the defrost thermostat while it's covered with frost. It needs to be below 40*F to show continuity. If both check OK for continuity, the defrost control/timer has failed and must be replaced. On your model the heater never goes out and it's common for the ADC to fail. Once you determine which part needs to be replaced, defrost the entire evaporator with a hair dryer and get all the frost out, replace the cover back over the evaporator or the unit will not cool properly. The refrigerator will work normally until you replace the part. It takes a couple weeks to build up with enough frost to start affecting the cooling again
Jun 20, 2017 | Refrigerators
Samsung RS267LBSH/XAA evaporators (both the refrigerator and freezer sides) building up with frost. It works fine for about a week after defrosting with blow dryer, and then same problem happens.
Your defrost heaters are not working. The unit takes a week to freeze up and presto - poor cooling. Melt the ice and it works fine again till it freezes up again. Did you check out the defrost timer? Make sure that the defrost elements are not open.
Apr 30, 2017 | Samsung Refrigerators
The Evaporator freezes and fan down by evaporator does not work
Replace the fan that is not working and then see what happens. If evaporator still freezes up after the replacement then the defrost circuits need attention - i.e. the defrost timer, defrost heater element, defrost thermostat.
Aug 19, 2015 | Refrigerators
I am looking for a defrost heater for my samsung side by side modle rs2534ww/xaa
the heater for the freezer evaporator is directly under the coil in the lower rear area of the freezer/the heater grid for the refrigerator is in the front of the evaporator coil in the rear wall of the refrigerator compartment
Jul 15, 2010 | Refrigerators
Refrigerator warm, display blank but freezer still works
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*#$^
Feb 21, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
SAMSUNG RB215LASH fridge coil iceing up
Don't think its a control board. I think you need to see if Samsung has a longer sealed system warranty. I think at this time the repair should fall back on Samsung 5 year sealed system. I can send you the service manual and the evaporator information if you like. The problem is most likely a defrost heater in the fresh food evaporator has become defective. And it cannot be replaced without removal of evaporator and heater together. Some idiot had the idea of weaving the defrost heater into the evaporator coils on your model. The heater is part of the evaporator. Which I would say now is part of the sealed system. I think you need to have a talk with your nearest Maytag service team. Samsung is a division of Maytag and because of the issue of the defrost heater being not replaceable without breaking into the sealed system Maytag may honor your concerns. Sorry I could not bring better news. But feel it's better to let you know. If you need me let me know, Thanks, Sea Breeze
Jul 18, 2009 | Samsung RB215LASH
Not getting cold
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Would also appreciate if you could provide us the model number of your fridge so that if the above solution does not resolve your issue would look into the matter specific to your type of model.
I am sure this solution would help you to resolve the issue.
God Bless
Jul 13, 2009 | Whirlpool Refrigerators
Replaced the defrost heater but does not seem to working correctl
check the fan above the freezer coils (evaporator fan) and the defrost thermostat (located on the top of the coils), some fans won't run intill the defrost t'stat cools.
Dec 19, 2008 | Kenmore 53542 / 53544 Side by Side...
Ice Cube Tray Sticks
53282922_1db7fdbcf7_m.jpgHeavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams.
Jul 13, 2008 | Refrigerators
Kenmore Er dh
Apr 12, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refrigerators Logo
146 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
