Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
My hard drive will not power on at all, can you help?
  • John Waters
    John Waters May 29, 2011
    have you tried changing out the usb power cable?
    Problem Solver:
  • 19 Answers
To start if there is an AC adapter I would check it's working. This is very easy if you use a multimeter. If it is working, you should then check the disk manager if you're using windows. To do this hit Start, Run, "compmgmt.msc". There you will see a title on the left "Disk Management", click it and see if your hard drive is listed there, then report back.
Posted on May 29, 2011
Noontec hard drive power problem
1. Check your power lead make sure both ends are plugged in and switch on.
2. Replace Power lead
3. Rehouse the drive (This is not hard and there are a lot of youtube clips that can help you)
Jan 27, 2014 | Hitachi Computers & Internet
Hardrive only flashes
Nothing Happens When Drive Is Plugged In b> Remove the USB or FireWire cable from the back of the hard drive and try using a different one. If the hard drive requires external power, try a different power cable and power outlet. Visit the hard drive manufacturer's website. All prominent hard drive manufacturers have utilities that can freely be downloaded, which will check the hard drive for errors and diagnose problems. Sometimes, these utilities can repair problems that Windows Disk Management cannot. Call the manufacturer to obtain a replacement hard drive if the utility reports errors or does not see the drive at all. Hope this helps.
Dec 28, 2012 | Samsung S2 - 1TB USB 2.0 Portable...
HOW DO I KNOW THAT MY HARD DRIVE IS CONNECTED
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
b>
Dec 21, 2012 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
Dane elec portable hard drive not recognised by win 7 pc
Power up the drive.
Hope this helps
Nov 01, 2012 | Dane Elec DANE-ELEC SoMobile 500GB USB 2.0...
Cant open my hard drive in my laptop
Locate the power cable and USB cable that came with your hard drive.
Connect cables to the appropriate locations on the back of the hard drive.
Sometimes a USB cable doubles as the power source, so you might not need a wall outlet to power the device.
Turn on your computer and allow your operating system time to load before continuing.
Plug the hard drive into the power outlet if necessary, but wait on powering up the device.
Connect the USB cable to the computer while the hard drive is in the "Off" position.
If the USB cable doubles as the power source, the device might turn itself on once connected.
Turn on the hard drive and wait until the hardware has been detected by the operating system. A message should pop up that lets you know new hardware has been detected.
Click on the "Start" menu and go to "My Computer."
Notice all your disk drives are listed in this window. The external hard drive should be visible, and holding the mouse cursor over the location will help you locate the correct drive.
Right click on the location of the drive, and move the cursor to "Open" or "Explore" and click.
Hope this helps
Sep 26, 2012 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have a Hitachi internal hard drive that i would like to use as an external hard drive to boot from my e-sata port, i have a Toshiba portege and i curently use two hard drives to boot from, one for work...
yes you need power to the external hard drive whether ide or sata possibly depending on your hard drives power supply
12V+5V AC sata Adapter Power Supply HDD HARD DISK DRIVE
hope it helps
Mar 27, 2012 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
I have LaCie 500 GB Exernal Hard Drive. I was transferring some data from my computer into the hard drive. The hard drive fell off and stopped working. When i connect it to power, the power light doesn't...
Sounds like the power supply in the external case has gone bad (or going bad)...
If you have another external case, AND the drive itself is not damaged, you can move the drive to an external case.. Alternately, depending on the connection (IDE/SATA) you can move the drive internally to your computer.
Jul 20, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Dead hard drive
Try unplugging the usb connector and plugging it back in. Your pc shouls recognize the installed component automatically. Also, some external hard drives work like normal pc's do: hold the power button in longer until something happens. Hope this helps.
May 24, 2009 | LaCie (300770) 250 GB Hard Drive
Freeagent desktop external hard drive will not power up
I have my own Seagate hard drive and with mine you have to plug it into the computer and power source for it to power on.
Jan 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Don't remember how to use
I also have a Monsoon 320GB hard drive.  There is a power cord that attaches to the hard drive and the power source, make sure that the drive is turned off, plug the power cord in to the drive and the power source.  Mine came with two types of connectors to connect the hard drive to the computer.  Firewire to Firewire and a usb cord.  Use one of the cords to connect the hard drive to the computer.  Then turn your drive on.  If an icon doesn't show up on your desktop you can restart your computer, that usually works for me.  The drive functions just like your internal hard drive.  If you want to save files on the external drive just choose that option when saving a file.  Hope this helps.
Jul 30, 2008 | EZQuest Monsoon Hard Drive
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
66 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
