Question about Cosmi Caillou Kindergarten Full Version for PC (CDRS517)
I installed Caillou Kindergarten on my windows 7 64 bit laptop and the coloring book portion doesn't work. It comes up fine and allows you to pick a color but doesn't color anything. The picture stays white. Please help... thank you.
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Just did a clean install of Windows 7 (64-bit) don't have the original discs. Everything appeasr to be working fine. but what order do i download the drivers in?
It doesn't matter what order you download the drivers. I normally do my network drivers first so that I can use the internet to download the others.
Jun 07, 2012 | Sony VAIO VGC-JS210J/B 20.1 in. PC Desktop
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
Connecting projector to laptop works at first windows xp comes up but soon as go to welcomne screen projector says no signal??
Your laptop should have a FN key and an 'F' key (The image on the key looks like two monitors side by side or it will say LCD/CRT) which you need press simultaneously to allow the laptop to send the signal out through the VGA port. Usually I have to repeat the process three times to allow the image to be presented on both the laptop screen and the projector. If this still doesn't work, go into desktop properties, advanced and unclick the square saying 'extend to..............' (sorry I can't remember the rest of the extend bit as I am in front of my PC not laptop and the settings are different. You should find it though.
Good luck
Aug 11, 2011 | NEC VT575 LCD Projector
I connect both the printer and the PC to a Wi Fi LAN, but the computer doesn't find the printer. When I connect the printer to the PC through a USB cable, it works fine, still it doesn't work in...
Ah yes this problem. i have come across it a few times. unfortunately your do not say what make and model you have. You MUST follow the instructions in your user cd. If it is one of the new Canons then you must connect vis usb first then install the wireless from the disk. That is the only way u can install it. Other manufacturers have other ways. Read the manual. Srri
May 10, 2011 | Office Equipment & Supplies
Hi I have purchased Grandma and Me for my four-year old nephew but I can't get it to run. I installed it and I got a message saying that the product had installed successfully. When I click on the...
Several older Living Books wouldn't run in XP until right clicked and changed properties to force it to run in 640x480 and in 256 colors. I am getting the 'missing book outline file' when I try to copy and play the contents of Cat in the Hat cd to hard drive. My daughter has trouble changing out the CDs herself, so the ones that cannot be installed directly to and run from hard drive, instead of CD will not be used by her nearly as much because she won't ask for help, she'll try icon and if it doesn't work, will just move on to some other game. The Cat in the Hat will install a launcher and run from CD fine, it just prevents full install and run from hard drive with that 'missing book outline file' which seems as though it may be intended to prevent install and run from hard drive rather than cd. I have not yet found solution for that. I was able to install Grandma, Harry & Haunted House, Little Monster and Arthur's Pet Chase to hard drive of XP machine. On one or two of them, before I could get it to run from hard drive, I had to edit the .ini or config files and change the location from d:\ to c:\program files\livingbooks\...folder where .exe resides on hard drive. My 2 cents. Hope that helps someone else.
Apr 04, 2011 | The Learning Company Just Grandma and Me...
I have a Futura CE-100 and got a new laptop with Windows 7 and can not get the software to install. Gets to 100% and won't complete. How can I fix this?
First, there's a Windows 7 update available at www.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALL Futura software you've attempted to install and reboot your PC.
If for some reason this doesn't solve you're problem, I've posted a set of instructions at http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista that will allow you to run the software under XP on your Windows 7 machine. This is a bit more complicated a solution, but if you follow the instructions carefully, you should be fine. Try the Futura update first, though.
I hope this solves you're problem. Happy embroidery!
Nov 23, 2010 | Singer CE-100 Futura Computerized Sewing...
Backbeat 903 headphones won't pair with Windows 7 64-bit laptop
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/ or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
Jan 28, 2010 | Altec Lansing BackBeat Plus Mobile ...
Cosmi Caillou Kindergarten Full Version for PC (CDRS517) Logo
152 people viewed this question
Top Cosmi Computers & Internet Experts
Tony
raysaw
Are you a Cosmi Computer and Internet Expert? Answer questions, earn points and help others
