Question about Garmin nuvi 255W GPS Receiver
My garmin nuvi 255w keeps freezing up at loading maps screen...i have tried the hard reset but that doesn't work, when i push on the bottom right corner and start the gps, it doesn't even make it to the loading maps screen it just stays on the garmin screen and than shuts off.
  • 343 Answers
There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker. Once you get it going fully charge the unit then go to the Garmin website and register and update your 255w. I will attach the link to the Garmin Site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
Posted on May 29, 2011
Can't unlock maps on garmin nuvi 255w after update
You can try to power down for hard reset(disconnect battery) and after connect again or reset to factory setting.
Mar 19, 2013 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download Nuvi 255W Manuals here.
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Garmin Nuvi 255W Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Does your Garmin Nuvi 200 or 200W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 255W GPS unit.
I hope that helps.
Backup & Restore Nuvi Favorites here.
Download Nuvi 200W Manuals here.
Download Garmin WebUpdater here.
I power my nuvi 255w on and it says loading maps but doesnt and it makes a beep and powers off. there is no reset button on this unit and i don`t know what to do to get it to come on and stay on? ty
Hold the power button for more than 20 seconds till it restarts - this is a soft reset. Then try again.
If that doesn't help, do a master reset which clears all user data back to the factory state. From powered down, turn the Garmin on while holding the right bottom corner of the screen for at least 20 seconds. A question should appear if all user data should be cleared. Then try again.
When it works again I would suggest to update the software in there till the latest version available on Garmin.com
Jul 04, 2011 | Garmin nuvi 255W GPS Receiver
I have a Garmin Nuvi 255w. I've had it about 2 yrs ago. Had recently gotten message that I needed to update maps, so I went on the website to see how much it would cost. Decided not to update maps,...
Did you try a reset. There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker. It will clear out all you favorites etc.. so copy them first if needed. Gently push the reset and it will reboot and ask to confirm and choose yes. See if this works
I will attach Garmins contact info. Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 15, 2011 | Garmin nuvi 255W GPS Receiver
Nuvi 255w freezes on garmin loading maps screen how do i get working again
Add a comment
May 05, 2011 | Garmin nuvi 255W GPS Receiver
How do i restore my gps back to factory setting with nothing on it. my brother gave it to me and it has pictures on it that i would like to remove. especially the start up screen. please help me. i find...
Good Luck
Nov 08, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
May 11, 2010 | Garmin nuvi 255W GPS Receiver
My NUVI 1300 has frozen at the "Loading Maps" screen. It also freezes when connecting to my laptop so I cannot perform an update. I've tried touching the bottom right while powering up and have erased...
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Feb 12, 2010 | Garmin nuvi 1300 Car GPS Receiver
New Garmin nuvi 255w suddenly not working
Those are severe symptoms.
A Hard Reset is a good idea after a firmware upgrade.
There are three levels of getting your Garmin 255W's attention and correcting bad habits (ie: not loading maps or locking up).
The first is 'soft reset'. There is a reset button along the bottom of your gps. Push and hold it until it restarts. If you cannot locate your reset button, sliding the power switch to OFF and holding for 8 seconds should do the same thing.
The second method is a 'hard reset' or 'clear all user data', to restore factory defaults.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
The third method is a firmware upgrade via Garmin's Webupdater, or the myGarmin site.
Run through these fixes to get your Nuvi running as good as new.
I hope that helps.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
1,328 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
