Hi and welcome to FixYa, I am Kelly
The HH60 is the engine model number and 105113H is the specification number. (Good thing for the purpose of this post.) It is a 6 Hp Tecumseh.
The service manual for your engine is here:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_3HP_TO_11HP_4-CYCLE_L-HEAD_FLAT_HEAD_ENGINES_692509.pdf
See page 71 for troubleshooting / testing the ignition system
There is a kill wire that is attacted to a terminal of the throttle control plate that can NOT be grounded or it woill ground the ignition. That same lead can NOT have any grounds all the way to the ignition coil. (This is called a parasitic load) Most of the time when a new condensor is installed the problem is where the wires attach to the condensor. (Chassis ground)
Coil to Flywheel air gap is 0.0125 measured at the magnets to the coil.
The wire that connects to the stop start switch will also ground the ignition.
Thanks for choosing FixYa,
Kelly
Testimonial: "Very Good Thankyou"
What does flyWheel Key have to do with it?
