Question about Garden
I need to know torque specks and tighting sequence for a cylinder head on a 19.5 hp briggs and stratton model number 461707 0145 e3
  • 252 Answers
Here is web site for manual
http://www.briggsandstratton.com/engines/support/operators-manuals/?NTT=+461707+0145+e3+
from the top of my head 160 in/lb torque setting
pattern gos top centre , botm left,top left , centre right , top right , centre left , centre right then centre left , then botm right
cheers pauly46
Posted on May 30, 2011
Torque spec on 21 hp briggs and strattonand sequence
Doug, Torquing multiple bolts, like on a cylinder head are shown in last video link.Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
FAQ Small Engine Specifications Briggs Stratton Specs
Engine mounting pattern
HOW TO LOOK UP AND TORQUE BRIGGS HEAD
How to replace Briggs Stratton Intek Head Gasket Pt 2
Jun 01, 2016 | Cars & Trucks
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
Does anyone know the head torque specs and tightening sequence (if necessary) for B&S 42A707 Type 2238 E1 17 HP? Thanks.
briggs has service manuals available on their website... take those numbers and search... and yes. they have a sequence and a torque spec. which is 160 inch pounds
Oct 25, 2014 | Briggs & Stratton Garden
Head bolts torque sequence on Briggs & Stratton model number 331877
If you don't have the proper sequence then the general rule is to do a cross pattern. Do one bolt on your left then one on your right then left etc. When torqueing head bolts you need to torque in three stages. figure out your torque spec then divide by three. That # is your first torque. Do all bolts to this and then do the second torque then the last torque which should be the f/lbs you need to be at
Jul 27, 2014 | Garden
What is the torque sequence on a 18 hp. v twin motor briggs and stratton motor
If your talking about the cylinder head bolts. I don't know the exact sequence but I was a truck mechanic for forty years and went by the rule of thumb to start in the center and work towards the ends. That way you avoid a buckling o9f the head.
Jun 16, 2014 | Craftsman 42" Briggs Stratton 20 hp Gas...
Torque for oil pan on 16 hp vanguard
You should not need torque on those bolts..just need only a few lbs..enough to sets the gasket tightly...I use a small hand wrench and tighten hand tight holding the wrench at the head part of the handle..this will give you plenty of torque without fear of stripping the threads..if you want, re tighten after the engine warms up to operations temp..just a suggestion how I have done it successful many times..good luck..
Apr 26, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Jul 10, 2009 | Garden
Garden Logo
503 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
