Question about Slime Tire Sealant
I use Slime in my bike tires and am following dealers recommondation that I pump up tire to 40 lbs pressure every 2 weeks.I am encountering problems inflating tires.It seems that the Slime will not allow air to enter tire.Three different tubes this month!
    Sergeant:
    Champion:
  • 218 Answers
I am pretty sure on the slime I use that it says I had to ride the bike immediatley after I put it in for about 5 miles, this was to throw the slime to the outer edge, also have you tried with the valve at the top of the wheel when pumping?
Please let me know if this doesnt help, if it does however can you rate my answer.
Posted on May 29, 2011
How to reset the tire pressure low light on a chrysler 300
It is supposed to reset automatically when driving after you pump the tires back up above the minimum threshold pressure. However this does not always work.
What you need to do now to reset it is to pump all the tires up around 6 - 8 lbs psi above where they are now when COLD (up to 40 lbs psi COLD on each tire is fine). Then drive around for a few miles and the warning light should reset. Then when the tires are cold drop the pressure to around 36 psi cold or a higher pressure setting if you prefer. If you don't have your own tire pressure gauge then go to an auto store and buy one as good gauges are not expensive.. (Just avoid the cheap plastic ones).
The TPMS sensors fitted to the wheels can be erratic and whilst they are supposed to trigger when a low pressure is reached, the minimum pressure can vary significantly for the same model sensors fitted to different cars of the same brand/model/year.
Mar 29, 2016 | Chrysler Cars & Trucks
Tip
Pump Them Up tip
Often Bicycle tires lose air slowly. It's just their nature. Because they don't hold a lot of volume of air and because that air seeps out over a relatively short period of time (a week for a road bike tire and about two weeks for a MTB knobby), there's a risk if you just ride without checking the tire pressure. If you bike on soft tires and you hit a pothole, rock or other obstacle, it's possible to damage or ruin, the tire, tube and worst of all, the rim. A too-soft tire also means that you're working a lot harder and on a mountain bike, it can make for a wobbly, hard-to-handle ride. So, be smart and check your tire pressure regularly: every week during the season for mountain bikes and before every ride for roadsters.
on Dec 21, 2010 | Cycling
Correct tyre pressure chart
Hi Anonymous, factory recomended tire pressure for a 2011 XL 1200X is: front tire 30 lbs. rear tire 36 lbs. solo 40 lbs. double. Good luck
Apr 07, 2014 | 2011 Harley Davidson XL 1200X FortyEight
2010 Honda Civic Hybrid...Tire Low light came on...I continued to drive and the tire lost more air. Then a horrible sound came along. It sounds like something hitting the wheel well. I thought for sure...
Try to do your inflations when the tires are as close to cold as possible, ie: at the closest practical gas station. The further you've driven the more they will warm up. The tire pressure spec. on the sticker in door well is cold pressure. In a pinch when putting in air after driving a "fair" distance, go 2~4 lbs. over, and then recheck when cold.
Also, how good is your gauge? Are you using your own, or the gas station's, or just that funky thing on the pump hose?
Also, consider bumping them up, say to around 40 lbs (verify the max pressure indicated on the sidewall is still higher, likely 44). This will be more likely to rule out measurement inaccuracies, and improve your mileage as well. The only downside is a harsher ride.
Please check for the following conditions:
* Low tire pressures. Raise the tire pressure to a "recommended" setting, preferably close to or at the tire's maximal pressure rating.
* Perform a four wheel alignment and look for signs of unusual tire wear.
* Add additional insulation to the rear passenger and cargo area of the vehicle.
* Check for a defect in the rear control arms as identified in service bulletin 08-001 affecting primarily 2006 and 2007 models. This defect is responsible for abnormal tire wear, noisy operation and even responsible for poor directional tracking at highway speeds.
Keep us updated; hope helps.
Mar 10, 2011 | Honda Civic Cars & Trucks
How to Maintain a Bike's Tire Pressure for Good Performance?
Buy a good floor pump with a gauge (see "How to Buy a Bike Pump," under Related eHows). A small, frame-mounted pump is useful only for roadside repairs.
Understand that it's normal for most tires to lose up to 10 pounds per square inch (psi) per week. This does not mean you have a slow leak.
Look on the tire's sidewall for tire pressure recommendations. Don't exceed the maximum tire pressure listed.
Inflate your mountain bike's tires to 40 psi for dirt riding. You may wish to inflate your tires to 50 to 60 psi for city riding.
Inflate your road bike's tires to 100 psi for road riding. Some road tires have much higher psi ratings. However, 100 psi will provide a good mix of performance and comfort.
Inflate your hybrid bike's tires to 60 to 70 psi for city riding.
Check your tire pressure before every ride
How sohuld I take care from my bikes tires?
It is important to get your tires checked from time to time. Second only to wear and tear resulting from dirt,the biggest problem cyclist encounter is with tires. Many inexperienced cyclists tend to ignore the tires. This can lead to dangerous issues. Bicycles tubes are made from a porpus type of rubber called buytl rubber, which allows air to slowly seep out. If tires are not regularly re-inflated to proper volume, they will be to soft. Apart from being much harder to pedal with, soft tires also lead to rim, tube and bicycle wheel damage.Soft tires wear out much faster, and can pop unexpectedly,leaving you stranded. To ensure that tires are propely inflated, pump up road bike tires before every ride, and check mountain bike tires every week. Use an effective pump, ideally ,a bicycle pump with a build in gauge, and observe your bicylce manufaturers information about recommended tire pressure.
Warning light under the D on the dashboard
This symbol is the tire pressure indicator. If you are running the factory stock tires on the car then inflate your tires to between 36 and 44 lbs. 44 lbs is max pressure so you would be safe running around 38 or 40 lbs. Once you do this then turn your vehical off and restart it. It should reset the sensor and show enough tire pressure to turn the sensor off.
Nov 09, 2010 | 2008 Chrysler Pt Cruiser
What is the tire pressure required for a 700c Denali Model# ov52706?
Look on the sidewall of your tire and see what it is rated for. Also, do not go to a gas station to fill it up, go to a bike shop and ask them or buy a bicycle pump with a gauge. Always make sure that your tire is seated on the rim evenly or you will pinch the tube and it will blow up. Car tires have more volume so that is why you cannot use the same air pressure device. Your tire will say 90-120 lbs more that likely but your tires is not that big around.
Sep 19, 2010 | GMC Denali 700C Road Bike
Recomende tire pressure touring motorcycle
Generally I put the front and rear tires @ 40 psi. You get better gas mileage , plus it rolls better when you have to push it around, but you also get better tire wear. I would set your rear air suspension around 12 -15 psi.
Mar 20, 2009 | Harley Davidson 2007 Harley-Davidson FLHX...
Tyre pressures and oil grade.
gearbox oil-20w/40 0.73 qts. cooling system-1.26 qts. 50/50 mix 2-stroke oil-shell racing x/40 fuel grade-98 spark plug-ngk r 6918-b8 spark plug gap--.024" main jet-190 idle jet-48 needle position-3 pilot screw # of turns out-1.5 rear tire pressure-14 lbs front tire pressure-14 lbs keep air filter element well cleaned & oiled w/ air filter oil.there are service manuals available for this model.
Feb 18, 2009 | 2003 KTM SX 125
Slime Tire Sealant Logo
201 people viewed this question
Top Slime Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Slime Cycling Expert? Answer questions, earn points and help others
