Question about Whirlpool Dryers
I have an Estate gas dryer and it does not get the clothes all the way dry on the timed setting and on the sensor setting the knob never moves. It just stays at the start of the cycle. The dryer starts off warm but cools as it continues through the cycle.
    President:
  • 3,074 Answers
Disconnect the vent tube and run a load of clothes, then clear the vent tube of the restriction, Tim
Posted on May 29, 2011
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Wirlpool Estate Gas Dryer that does not dry
i think your temperature sensor is defective in the dryer section..
check it out
May 04, 2008 | Dryers
Drier dries too slowly. it does heat up but i always have to turn on again for 40 more minutes to complete drying. it does get hot. and i am not overloading.
You do not state if you are using a machine with an automatic drying sensor. If so the calibration of the sensor is off. Try setting the control to a dryer setting. If you are using it by time only, it would appear there may be a blockage in the air outlet. Check the damper flapper at the output of the air vent. It might be partially stuck closed thus reducing the air flow around the clothes. Just a thought that your washer spin dry may not be sufficiently spin drying the clothes and so that the clothes are overly wet when put into the dryer..
Oct 05, 2011 | Estate TEDS840JQ Electric Dryer
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
Dryer does not stop - timer knob does not turn so dryer continues
do you have it on more or less?,if so the timer will not move unless there is heat, do you have heat?are the clothes drying ?if you have it on time dry the timer is bad try moving it past the spot were it's sticking and see if it counts down
Nov 03, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Mar 26, 2009 | Whirlpool Dryers
Auto Dry not advancing
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
May 30, 2008 | Kenmore 73952 Gas Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Dryers Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
