Question about Garden
When i dich in gage the cluch the motor will shatoff or in gage the mower it will shut off .and put it in gear it will shut off.
  • 927 Answers
Check your seat switch. If the switch thinks no one is in the seat, it won't allow the mower to move or blades to turn.
Let me know,
Gary
Posted on May 29, 2011
My huskqvarner lawn mower shuts off when you put it in gear or reverse. It starts good but when we try to do anything with it it shuts off
Look under the seat for a switch. This is a safety interlock that shuts off the engine if you fall off. If the switch doesn't activate then the mower thinks you are not in the seat and shuts off the motor.
Apr 03, 2016 | Garden
Why will the motor stall when put into gear or trying to in gage the mower deck
You may need to lubricate the bearings on the deck or change them out.
Jun 19, 2015 | Garden
I have a 1998 toyota 4 runner 2 wheel drive 4 cylinder new motor new trans, but won't in gage to move it sat for 8 years before installing new motor and trans it has all spec's in oil
A lot of times if set that long the cluch bands in the transmission get dry if you will push or pull while in gear the pump will pick up and it will start pulling
Jan 03, 2015 | Toyota Cars & Trucks
I have a 2003 Honda Gold Wing California Side Car trike conversion - Radio is all original equipment... Radio will play on AM, FM1 and FM2 if ignition in ON poition (motor not running).....will not play...
I have same ride same problem put your ear down by the cluch lever and you will hear a click when you let the cluch out the same time the radio quits if you take the switch off and hold it closed the radio will work all the time
May 19, 2011 | 2003 Honda GL 1800 Gold Wing
Poulan riding lawn mower starts but won't shift into any gears
your cluch is not disengaging when you step on the pedal check ajustment on cable tighten cable and try again...good luck
Apr 10, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
HELPING A FRIEND WITH A CRFTSMN 18HP FRNT ENGINE LT2000 LAWN TRACTOR. THE ENGINE RUNS GREAT BUT WHEN HE RELEASES THE CLUTCH/BRAKE TO GO FORWARD OR REVERSE THE ENGINE DIES.
Put trans in neutral if trans is a gear drive and see if mower can be pushed, if it can you can push rule out stuck brake. If you have a hydrostatic trans you can put trans in bypass and push to see if brake is stuck. Remove drive belt at engine or at trans and try the cluch, if motor stays running there is a trans problem.
Mar 13, 2010 | Craftsman Garden
96 yamaha serow locked up
can you still turn the motor over by hand???
is the gear box seized??? test it this way,, put it in gear and pull the cluch in now try to push the bike along, if it wont more its the gear box or chain drive it may have come off the front sprocket and jamed it or iv even had a big rock find its way in there and that jamed it too?
Oct 23, 2009 | 2001 Yamaha Serow 225 WE
My 250 honda rebel runs fine in neutral but shuts off when i put it in gear. When i don't have the cluch engaged it lurches foward slightly then shuts off.
Check the side stand kill switch. Broken, loose or out of adjustment it will kill the bike when put in gear. The idea is to prevent starting out with the side stand down. Check the wires and connections also.
Jul 01, 2009 | 2000 Honda CA 125 Rebel
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
