Question about Samsung SCX 4521F All-In-One Laser Printer
Proper Settings with TAD
How do I plug a new 6.0 digital cordless telephone (Panasonic Model KX-TG9331T) SO BOTH MY Samsung all -in-one and telephone work properly and I can receive faxes and messages into th same phone line when I am not here to manually notify that is a fax coming and not a telephone?? Is not working right. Do I plug cordless phone into phone wall jack first or Samsung SCX-4521F into phone wall jack first. What about rings to answer on fax- What setting? How many rings should I set on the answering machine? There was no book or CD with my printer so I have had to learn by doing. ladylawyer7@sbcglobal.net in Texas
  • 2 more comments
  • ladylawyer Aug 16, 2008
    I did this before I asked FixYa. Try again.
    Need another solution. I did this before I asked fixya. The splitter is in place and is not working properly.
  • ladylawyer Aug 17, 2008
    How about another expert, so far everything tharufen suggested including the error 404 link to the manuf web post of manual is incorrect. Anyone out there who is not so smug and will help or has other suggestions?
    Yes, this one worked and the problem is corrected. Receiving the link to the manual is really helpful. Thanks so much
  • 1,800 Answers
Try to benifit from this manual click here
Posted on Aug 17, 2008
    Brigadier General:
  • 6,966 Answers
Initially, pls try connecting the Panasonic KX-TG9331T to the telephone port marked "EXT." at the back of the Samsung All-in-One. At nearly the same location, there would be a telephone port marked "LINE" that should go to your wall telephone outlet.
Specific settings and configurations (as you posted) are better explained in the user's manual of the Samsung SCX-4521F which may be found here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 928 Answers
What you are looking for is called distinct ring. You have to subscribe to this via the phone company. There will be a specific ring on the phone to tell whether it is a call or a fax. You can then set the fax to listen for that specific tone then to activate when it hears that tone. hence you will get the fax. You can then go to the link below for the manual to setup the distinctive listen on your samsung printer fax
http://www.samsung.com/us/support/download/supportDown.do?model_nm=SCX-4521F&mType=UM&vType=L&disp_nm=SCX-4521F
Posted on Aug 16, 2008
  • 1 more comment
  • Thomas Lim
    Thomas Lim Aug 16, 2008
    It is called DPRD by the way DRPD (Distinctive Ring Pattern Detection)
  • Thomas Lim
    Thomas Lim Aug 17, 2008
    Receiving Faxes Using the
    DRPD Mode
    “Distinctive Ring” is a telephone company service which
    enables a user to use a single telephone line to answer several
    different telephone numbers. The particular number someone
    uses to call you is identified by different ringing patterns, which
    consist of various combinations of long and short ringing
    sounds. This feature is often used by answering services who
    answer telephones for many different clients and need to know
    which number someone is calling in on to properly answer the
    phone.
    Using the Distinctive Ring Pattern Detection feature, your fax
    machine can “learn” the ring pattern you designate to be
    answered by the fax machine. Unless you change it, this ringing
    pattern will continue to be recognized and answered as a fax
    call, and all other ringing patterns will be forwarded to the
    extension telephone or answering machine plugged into the
    EXT. jack. You can easily suspend or change Distinctive Ring
    Pattern Detection at any time.
    Before using the Distinctive Ring Pattern Detection option,
    Distinctive Ring service must be installed on your telephone line
    by the telephone company. To set up Distinctive Ring Pattern
    Detection, you will need another telephone line at your
    location, or someone available to dial your fax number from
    outside.
    To set up the DRPD mode:
    Press Menu until “Fax Setup” appears on the top line of
    the display.
    Press the scroll button ( or ) until you see “Receive
    Mode” on the bottom line and press Enter.
    Press the scroll button ( or ) until you see “DRPD Mode”
    When “Set” displays on the bottom line, press Enter.
    “Waiting Ring” appears on the display.
    5
    Call your fax number from another telephone. It is not
    necessary to place the call from a fax machine.
    6
    When your machine begins to ring, do not answer the call.
    The machine requires several rings to learn the pattern.
    When the machine completes learning, the LCD displays
    “End DRPD Setup”.
    If the DRPD setup fails, “DRPD Ring Error” appears. Press
    Enter
    when “DRPD Mode” displays and retry from step 3.
    7
    To return to Standby mode, press Stop/Clear.
    When the DRPD feature is set up, the DRPD option is available
    in the Receive Mode menu. To receive faxes in the DRPD mode,
    you need to set the menu to DRPD; see “DRPD Mode” on
    page 7.2.
    NOTES
    • DRPD must be set up again if you re-assign your fax number,
    or connect the machine to another telephone line.
    • After DRPD has been set up, call your fax number again to
    verify that the machine answers with a fax tone. Then have
    a call placed to a different number assigned to that same
    line to be sure the call is forwarded to the extension
    telephone or answering machine plugged into the EXT. jack.
  • Thomas Lim
    May I ask if you have seen the solution that I posted?
    Master:
  • 623 Answers
Buy a separator at electronics store
To set up my panasonic KX-TG633 cordlessphone
Print the Manual and read it cover to cover. Or online and read beginning to end.
ftp://ftp.panasonic.com/telephone/om/kx-tg633_en_om.pdf
KX-TG633SK - Panasonic
shop.panasonic.com > Get Support
Rating: 2.7 - ‎3 reviews
DECT 6.0 PLUS 3-Handset Expandable Digital Cordless Phone with Answering System.
[PDF]Operating Instructions (English) - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/telephone/om/kx-tg633_en_om.pdf Jul 15, 2016 - Operating Instructions. Cordless Telephone with Digital Answering Machine. Model No. KX-TG633SK. Before initial use, see "Getting Started".
panasonic kx tg633 manual Google Search
Aug 15, 2017 | Panasonic Lands Phones
I need a user manual for Pansonic model KX-TGF370.
Most Panasonic manuals are available on the product page or by searching here: http://shop.panasonic.com/support . The base has the model number KX-TGF370 . The Panasonic model number has a different final digit; that digit indicates the number of KX-TGFA30 handsets sold with the base.
The manual for the KX-TGF37x phones is available here: http://shop.panasonic.com/cordless-corded-telephones/cordless-telephones/KX-TGF37.html?supportpage=true#q=kx-tgf372&supportpage=true&PageName=true&start=1 . Scroll down or click on the Support link. The direct link to the manual is currently ftp://ftp.panasonic.com/telephone/om/kx-tgf372_en_om_.pdf .
I hope this helps.
Jun 19, 2017 | Lands Phones
Message light flashing with all messages deleted
This is probably the Voice Mail Warning Indicator
(VWMI) which alerts you to messages waiting in
your telephone services' Voice Mailbox --- this is totally
separate from the cordless phone's answering machine
and is prone to 'key on' even when you do not subscribe
the telephone services' voice mail.
You can download a copy of your phones manual from
http://www.manualslib.com/download/303942/Panasonic-Kx-Tg9331t.html
( be sure to ignore the advertising large button
"start download" and use the smaller button "download"
across the top banner "downloads" "table of contents" etc. )
then enter the security-codes & select 'download pdf'' etc.
Try the section on page 39-40 about Voice Mail Service.
To summarize, Turning VM signal detection on/off:
The default setting is "On", To turn this signal "off":
1. press [MENU] # 3 3 2
2. scroll up/down to desired choice
3. press [save] [off]
May 07, 2016 | Panasonic KX-TG9331T Cordless Phone
Phone says, NO NEW Messages, but light keeps blinking anyway.
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Sep 25, 2013 | Panasonic KX-TG9331T Cordless Phone
My phone says I have voice mail but I don't
You're apparently subscribed to a voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 02, 2012 | Panasonic Lands Phones
I have recently bought a Pnasonic Digital Cordless telephone Model KX-TG6411JT. Unfortunately the user manual is in Italian. I would like to get an English translation. Franz Vella
http://service.us.panasonic.com/OPERMANPDF/KXTG6411-MUL.PDF
or
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/Operating-Instructions/model.KX-TG6411T.O#ts
Mar 03, 2011 | Cell Phones
I NEED A MANUAL FOR A PANASONIC TALKING PHONE MODEL NO.KX-TG9331T ,CAN THIS BE E MAILED TO ME ?
Google is your answer. Per the TOS for this site, we are not allowed to email or contact other users of the site.
A quick google search found:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG9331T
Oct 10, 2009 | Panasonic Lands Phones
Display light is on but the words don't show up.
Dear a1trkr,
Press the menu button on the handset and type in (1) (4) (5) THen press 1-6 for LCD Contrast.
Hope that works! I have a panasonic and I love the clarity and range.
Best of Luck, The Writer.
Jun 02, 2009 | Panasonic KX-TG9331T Cordless Phone
How do you record greeting? i lost my manual for kx-tg9331t
Check on the web page for panasonic .
Type in your unit number after you get to the manual area.
Jan 28, 2009 | Panasonic KX-TG1033S Cordless Phone
117 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
