Question about Boston Acoustics MicroSystem CD High Performance Tabletop System Shelf System
My boston acoustics micto system CD will not power up after a power surge caused by lightning. How do I do a system check/reset on system
    Brigadier General:
  • 8,546 Answers
It's probably cooked.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on May 30, 2011
My Boston Acoustics ASW 650 just turned off yesterday and wont turn back on. What could be wrong?
Check for the wires connections on all the terminals.
Else it is a minor problem due to power fluctuations.
Take it to a nearby technician.
Sep 22, 2014 | Boston Acoustics ASW650 10in 650 Watt A...
Boston Acoustics TVEE 26 factory reset
Reprogram the remote to function with a different brand of equipment that you do not have. The remote can't affect the receiver if it is not talking to it.
Feb 23, 2014 | Boston Acoustics TVee Model 26
My Boston Acoustic Avidea 610 home theatre receiver popped last night and lost power! it has not been able to be powered up again!
Sounds like you blew a cap or some sold state device in the power supply section of receiver. Open her up and start looking and smelling - replace bad parts and cross fingers.
Aug 27, 2017 | Boston Acoustics Avidea 610 Theater System
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
My boston microsystem cd has stopped working. There's power, but nothing else. No clock, no sound nothing. Any troubleshooting suggestions?
I contacted Boston acoustics. I was told this is an intermittent problem with some units (mine is date april 2007). They say the radio will recover if kept unplug for 5 days. This is the time it takes for a huge capacitor on the main PC to discharge completely. They say a firmware upgrade can solve the problem.
So the idea is to leave it unplu for 5 days, plug it back and it should turn on again. I'm at day 3 and hpoing for the best.
Aug 28, 2009 | Boston Acoustics MicroSystem CD High...
We unplug our microsystem at night to save electricity. Now, it does not turn on although I can tell there is electricity because there is some light on the on/off button and display window, but the time...
I got the same problem. I wrote to Boston Acoustics to see what they say. I think the PCB needs to be replaced, but it shouldn't have failed in the first place. My radio just like yours worked perfectly before it was unpluged. It doesn't make sense that a radio that pricy fails just like that. I will let you know what Boston Acoustics says.
Jul 06, 2009 | Boston Acoustics MicroSystem CD High...
Have a Boston Acoutics Microsystem-all that comes on is the backlite on the display. No matter which buttons or combination, no response. 9 v battery fine. Simply won't come on. Anyone with any ideas?
See my other post. This is a common problem with this radio. Leave it unplug for 5 days, and it will recover. This is the time it takes for a huge capacitor to discharge inside. Somehow, unde rare circumstances, it locks the software. I was told by Boston Acoustic that a firmware upgrade solves this intermittent problem. If its still under warranty, ask for the upgrade. Otherwise, when it happens, unplug for 5 days and you're fine.
Apr 07, 2009 | Boston Acoustics MicroSystem CD High...
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
Speakers
The Boston Acoustics power supply that came with Model 7000596 speakers is rated:
Input 120VAC 60HZ 23VA
Output 12VAC 1500mA (1.5A)
The PS model number is WK1201A5-1AN
Dec 28, 2008 | Boston Acoustics MicroMedia Computer...
223 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
