Question about Canon Pixma MG6120 InkJet Printer
Finding mac address - Canon Pixma MG6120 InkJet Printer
    Problem Solver:
  • 10 Answers
To check the MAC address of the machine, use the up or down arrow buttons to display Setup on the HOME screen and press the right FUNCTION button,
then go to Device Settings > LAN Settings > Confirm LAN settings > WLAN setting list to see your MAC address details. YOu should see a screen that looks something like this:
WLAN setting list
MAC address
Printer name
Bonjour service name
Posted on May 29, 2011
Tip
How to find your MAC address using MS-DOS
The MAC address is the physical address your computer's Ethernet card or network interface card (NIC) uses to identify itself to other computers and devices on your network. There are different ways to find your Ethernet card's MAC address, depending on what operating system and programs you have installed. Since most Windows-based computers have access to the MS-DOS command prompt, using DOS to find your MAC address is one standard way to do it.
There are a couple of different tools you can use in MS-DOS to find your MAC address. All of them requiring opening a command prompt window, which you can do by typing "cmd" into the Run bar on the Start menu (or in Windows Vista or 7, you can type it into the Search bar instead).
- Getmac
Getmac is a utility that is included on Windows Vista computers and on newer Windows XP systems. Typing "getmac" by itself on a command line will return the MAC addresses of any NICs that you have installed in your computer. (If you have an Ethernet NIC and a wireless NIC, for example, Getmac will list the MAC addresses for both of them.)
- Ipconfig
Ipconfig is a command that will display your IP address if you are currently connected to a network. However, by adding the "/all" switch to it, you can also see your MAC address, as well as many other configuration settings. Type "ipconfig /all" and look for the line labeled "Physical Address." If you have more than one NIC, the MAC address for each NIC will be displayed separately.
on Oct 04, 2010 | Microsoft MSDOS 6 Upgrade Operating System
Blank wan mac address
You can't telnet based on the mac address you would be using the ip address. The mac is burnt into the device and isn't touched by a firmware update. If you did an update and the ip address changed, you can use a port scanner such as nmap to do a ping sweep and find the devices ip address.
Nov 17, 2013 | Computers & Internet
Does the producer of my Sony Vaio has my Mac address?
The MAC address of the LAN or wireless card is unique address (like a house number in your street in your town, state and country).
If you have not taken recorded this MAC address then you cannot supply this info.
There are millions of MAC address and Sony most likely do not have this info. If you have registered this laptop with Sony they might have this info.
Apr 19, 2013 | Sony VAIO Computers & Internet
How do i find out what my mac and ip addresses are?
Windows XP
  • The host name is your computer's name
  • Click the Start icon
  • Click Control Panel
  • Select Classic View
  • Click Network Connections
  • Right click on the connection you are trying to find the MAC address for and select Properties - you will have a separate MAC address for your wireless card and your Ethernet (LAN) card. Make sure you use the correct one.
  • Hover your mouse over the text box underneath connect using. Your MAC address will appear in the tooltip and is made up of 12 characters e.g. 00:11:22:AA:66:DD
To use your computer on AU network you will need to register this MAC address
Apple Mac OS X (Tiger)
Information Services does not provide support for the use of Apple Macs. However you may find the following instructions useful if you wish to use your Apple Mac on our network
  • From the Apple in the upper left hand corner choose System Preferences
  • Click on the Network icon
  • From the Show menu Select Airport (for Wireless) or Built in Ethernet (for Wired)
    • For the Built in Ethernet (for Wired) the MAC address will be at the top of the Ethernet tab as the Ethernet ID.
      The MAC address is the 12 character address e.g. 00:11:22:AA:66:DD
    • For the Airport (for Wireless) the MAC address will be at the top of the AirPort tab as the AirPort ID (or on the TCP/IP tab, again as the AirPort ID ). The MAC address is the 12 character address e.g. 00:14:67:F0:56:A4
  • To find your Computer Name go back to System Preferences and click on Sharing , your computer's name should be in the computer name box at the top of this window.
Apple Mac OS X (Snow Leopard/Leopard)
  • Select Ethernet for Wired or Airport for Wireless
  • Click on the Advanced button
  • Click on the Ethernet tab
  • Your MAC address will be at the top of this window as your Ethernet ID . The MAC address is the 12 character address e.g. 00:11:22:AA:66:DD
Linux
  • In a privileged terminal session type: ifconfig
  • This will show you a list of the network adapters installed. The MAC address is referred to here as the HWaddr
  • If you have a wireless card you will see more then one MAC Address, make sure you register the right MAC address.
  • To pick out your wireless MAC address type: iwconfig - your Wired one will be the other one
Vista
  • Click Network and Sharing Center
  • Select Manage Network Connections from the list on the left hand side
  • Hover your mouse over the text box underneath connect using . Your MAC address will appear in the tooltip and is made up of 12 characters e.g. 00:11:22:AA:66:DD
Windows 7
  • Select Network and Internet
  • Select Change Adapter Settings from the list on the left hand side
    You will have a separate icon for your wireless card; your Ethernet (LAN) card and your Virtual WiFi MiniPort adapter (if you have one), each with their own MAC address. Make sure you select the correct one.
Nokia mobile phones
  • On the home screen, enter *#MAC0WLAN# or *#62209526#
  • Your MAC address will appear as a popup and is made up of 12 characters e.g. 00:11:22:AA:66:DD
To use your phone on AU network you will need to register this MAC address
http://whatismyipaddress.com/
You can use this link to find out your IP address
Good Luck
Dec 06, 2010 | Computers & Internet
How do I find out what the mac address is on a
Just tap the Go button 3 times and it will print out the settings pages, on page 3 you will find the network settings with ip and mac address.
Jun 15, 2010 | Brother HL 5250DN Laser Printer
How to change mac address?
Every Ethernet card has a MAC address burned-in at the factory. At times, you may want to change this MAC address to one of your own choosing.
The procedures to change a MAC address are specific to each operating system.
How to change a MAC address in Microsoft Windows Under Windows, the MAC address is stored in a registry key. To change a MAC address, find that key with `regedit` and change it. Of course, Microsoft keeps moving the location of the key around!
Windows XP adds an option to change the MAC address on some network cards under the Advanced tab in the network adapter's Properties menu.
A much easier and more reliable method to change a MAC address under Windows is to use a software utility program designed to do this for you.
Macshift is a free utility that you can use to spoof your MAC address under Microsoft Windows.
How to change a MAC address in MacOS Instructions for changing the MAC address on a Macintosh can be found at MAC Spoofing on the Macintosh.
How to change a MAC address in FreeBSD In FreeBSD, you can change your MAC address with the `ifconfig <interface> link <address>` command.
How to change a MAC address in Linux Under Linux, you can change your MAC address with `ifconfig <interface> hw <class> <address>`, or you can use the GNU MAC Changer.
How to change a MAC address in Solaris In Solaris, you can change the MAC address with the `ifconfig <interface> <ether> <address>` command.
How to change a MAC address in OpenBSD OpenBSD does not, by default, allow you to change the MAC address. It is possible to change the MAC address under OpenBSD with sea.c.
How to change a MAC address in HP-UX Under HP-UX, you can change the MAC address in SAM by selecting Networking and Communications, then selecting the interface, then Action, Modify, Advanced Options. HP-UX refers to the MAC address as the "station address".
Changing a MAC Address in Hardware Speed Demon Adapters sells network cards which give you the ability to change the MAC address stored in their EERPROM.
This can give you the ability to change your MAC address under any operating system that supports either the PCI bus or PCMCIA Type II cards.
Feb 12, 2010 | Linksys WAG200G Router
MAC ADDRESS
- You have to set the Mac Address value after exchange PCB Assy.
(only Bluetooth product)
1. Disassemble the YP-T10 case and Find the MAC Address. (12 digit)
2. Open “memo pad” and write Mac Address on it.
3. Save “BDADDR”
4. Connecting USB, Copy “BDADDR” into Root.
5. To confirm Bluetooth Mac Address
- Power on
- “Setting – My Device Info – View the MAC Address”
6. If an error occurs, the address of the error is saved in
the ErrorMac .txt file as text
7. Mac Address Setting is done.
Dec 12, 2008 | Samsung YP-T10 Digital Media Player
No Internet With New Router, Computer, or Adapter
This document is relevant if you had an Internet connection, but lost it when: * Adding a router to your network, or * Using a different Ethernet adapter card or computer than the one your ISP used during installation. Use ISP Configuration to see whether you need to "spoof a MAC address" to connect to your ISP. If so, follow the instructions in this document. If the Ethernet card that was used during ISP installation is not available, you may need to register the new Ethernet card's MAC address with your ISP for the following to work. MAC address stands for Media Access Control address (not "Macintosh computer"!), a unique number built into modems, routers and other network hardware. It ensures that one piece of equipment is not mistaken for another one. Some ISPs validate your connection by checking the MAC address of the Ethernet adapter in computer that was registered during ISP installation. If you add a router or change computer or Ethernet adapter, these ISPs will drop your Internet connection, because they find the MAC address of the newly added router or adapter, instead of the one they expect. To fix this, change the router to report the Ethernet adapter's MAC, instead of its own. This is called "spoofing the MAC address". To find a PC's or Macintosh's MAC address, see How to Find an Adapter's MAC address : http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102075. To Spoof a MAC Address 1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records. 2. Disconnect other computers from the router. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.) 3. In an Internet browser type the address 192.168.0.1. 4. Type admin for the username, password for the password, and click OK. 5. Go to the Basic Settings > Router Mac Address. 6. Select Use Computer MAC Address. 7. Click Apply. This automatically gives the router the computer's MAC address. 8. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Finding the MAC Address of a Macintosh
Please follow the instructions which fits the Mac OS that is being run: OSX 1. Click on the Apple menu and select the System Preferences option. 2. In the "System Preferences" window, Select Network. 3. When the "Network" Window opens, select Built-in Ethernet and/or Airport from the "Show" Menu. 4. Once you do this, look near the bottom and you will see the Ethernet Address or Aiport ID. This is the MAC Address, make note of it. OS9 and below 1. Click on the Apple menu option. 2. Go to the Utilities folder 3. Open the program called Apple System Profiler 4. Select the System Profile tab 5. Under Network Overview > Appletalk> 6. Once there you will find the Hardware address, this is the MAC Address, make note of it.
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Canon Pixma MG6120 InkJet Printer Logo
1,015 people viewed this question
old marine
old marine
