Question about Compaq Presario 700 470024-192 Notebook
My wife's compaq presario f700 turns on yet the screen is really dim to the point of almost being all black! I can see some things with some strain or added light. Please advise.
    Genius:
  • 1,288 Answers
Screen backlight is probably failing, the fact that you are getting an image suggests that the inverter is ok (although replacement is often the only way of telling).
Firstly, plug the laptop into an external monitor, if the picture is clear, this will confirm that the issue lies with the backlight or the inverter, if however it does not, then you may have issues with the onboard graphics chip beginning to fail (expensive as it will need a new motherboard).
The only other cause can be a damaged VGA lead (unlikely).
Best guess would be that the laptop screen needs replacing, as replacing the tube for the backlight is a very difficult task and not really worth the effort or expense. You can find some good 2nd hand screens now for a 15.4 laptop quite cheaply and replacement is very easy
Posted on May 29, 2011
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
I have a compaq presario f700 it have a problem turning on the power vbutton will come on but it will then shut off. sometimes i have success for it to come on. when it comes on the windows loadin screen...
Compaq Presario f700 NOTEBOOK.
first off im amazed it can even blink bark or glow at all
laptop are scaled in DOG YEARs.
my first guess is the not tried yet, exernal VGA jack works
so only your screen is bad.
as all are now with CCFL lamps dead or its power pack.
called "inverter"
the lamps go dim, yellow ,flicker then die, all do if CCFL
best is upgrade top LED laptop and w7 and newer OS.
the BIOS pages must work or the screen is bad
seems power is ok, to me. and you.
it came with VISTA.
year 2007?
im reading your service manual now.
and see this?
that is CCFL lamp not LED>
this is bad or the inverter card that drives is is bad if BIOS FAILs
to show in the screen, My best guess, no tests by me,
testing is the only sure way to fix problems not guessing.
why not get tech to fix it?
capture-1z31dkbg41o2owghj0fas5br-1-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01095493
Jul 20, 2017 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario F700--the display on the monitor is mostly black or snowy, but when I plug in an external monitor, the external monitor works as it should. So you'd assume the screen is bad, right? I...
no photos, no joy
why post lacking the look, as your topic is all 100% Look.
a 2007 note book
the year or close to the year they made Nivida chip solderball , GPUs, that all fail.
so if its got that its, doomed, and buy 3 more used mobo
and all doomed sure
the screen is just a LCD screen and a backlight
if the digital data to it is bad (GPU) then the GPU is bad.
and hits soldered down,,,
buy desktop next time, and its child's play fix.
pop a new card
or and HP 9540w, that has cards !@!! and dont FAIL.
Oct 26, 2017 | HP Compaq Presario F500 F700 and G6000...
My hp f500 powers on but stays at a black screen and i dont know what the problem is need help
I have the same problem with the f700. tried replacing the inverter and even the screen but its something else... HELP?
Nov 20, 2010 | HP Compaq Presario F500 F700 and G6000...
Screen started to flicker when tilted, then the screen went very very dim,can only just see it. Whats causing it?
Hope this helps:
http://www.laptoprepair101.com/laptop/2009/05/04/how-test-lcd-screen-inverter-in-laptop/
Good luck
Oct 16, 2010 | HP Compaq Presario F500 F700 and G6000...
When i open the lid of my presario F700 it does not automatically show the screen. I have to move the lid over and over and over again to different points to get the screen to show.
In this regard there is something happen on the video card cable underneath on the hinge of the laptop. I have also Presario laptop that has same issue that you encountered.If you can able to open the laptop's hinge to check the video cable connection then you can check on it by resetting the connnection though. If your not able to do so either to go in the computer shop or have to call HP/Compaq for assistance. Thank you.
Oct 15, 2009 | HP Compaq Presario F500 F700 and G6000...
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Jul 02, 2009 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario F700 wont boot. Powers up then turns off again a
that means you might have a hardware failure. possible powersupply. check with local shop.
Jun 17, 2009 | HP Compaq Presario F730US Notebook
Blank (dark) screen
If you can still see a faint image on the screen, then its the inverter coil or the inverter itself which has gone bad or maybe even worked itself loose causing a bad connection.
Either way you will have to take it to PC repair shop to be looked at.
Good luck and thanks for using Fixya!
Jan 26, 2009 | HP Compaq Presario F730US Notebook
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
