The compressor does not shut off, it is constantly running. Even when the AC is turned off, the compressor is still running.
  • Walter Kunesky
    Walter Kunesky May 29, 2011
    when you shut of ac at thermostat does indoor unit shut down?
  • ed schartner
    ed schartner May 24, 2014
    yes
  • 41 Answers
It is possible that you have a stuck contactor get this fix ASAP or it can damage your compressor.The compressor does not shut off, it is constantly - raypena.jpg
Posted on May 29, 2011
  • russell boisseau Apr 27, 2012
    compressor will run constant even if air conditioner is turned off you have to unplug it to get the compressor to shut off
    thanks do you think the contactor needs replaced or is there a way to repair them i am familar with contacts at work we usally replace them if they are sticky but if we dont have new ones we clean them and reuse them. do you have a ideal were the contactor is located on the air conditioner>
I have indica dls 2010 car. compressor is not switcing on even i swith on the ac button . i disconnect the compressor wire and connected a wire from battory (+)to compressor. the compressor is on but even...
Hi Ravi,
yes when you connected the + wire to battery it wont turn off by using ac switch.
please un do the thing you done.
i think the problem is your system is out of gas or gas pressure drops required level.or bad timer relay unit .
the system has pressure cut out and if you are out of gas it shuts down the compressor and it is safty for compressor too.
regards,
nuwan
Jan 13, 2014 | Tata Indica Cars & Trucks
Compressor runs constantly,even when ac or defroster are turned off
you ac switch is melting in back you have to replace the hvca module
Sep 19, 2011 | 2005 Saturn VUE
I have a periodic clicking noise while driving my 2009 MKS Lincoln. Anyone have this happen?
The most common cause of clicking (under the hood) while driving is an undercharged AC system. The sound is the compressor constantly turning on and shutting off. The problem could also be related to the temperature control panel which could constantly call for the compressor to turn on and off.
Jun 02, 2011 | 2009 Lincoln MKS
I have a window air conditioner, Maytag, the compressor keeps running and will not shut off. I have tried turning it off and on, but it still runs. I tried to turn it off by the button on the AC, but...
The compressor is controlled by a contactor (relay) the relay is stuck (contacts burned or if a solid state relay the "smoke has leaked out" :) it may require a control board change if it is a modern unit
Apr 13, 2011 | Maytag Portable Air Conditioner M6P09S2A
A/C blows good cold air and everything works as it should, however when I turn the A/C on (doesn't matter what fan speed) I hear a constant clicking/ticking noise coming from what sounds like a fan
What you are most likely hearing is the compressor kicking on/off. The constant kicking could be a sign that there's insufficient refrigerant to keep the compressor running continuously without shutting on/off. Eventually, the compressor won't kick on at all, a safety feature designed to prevent doing damage to a compressor that's undercharged. Have the AC system checked.
Mar 29, 2011 | Kia Sorento Cars & Trucks
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a loud whining noise coming from my ac compressor. i have a 98 cadillac deville and it makes the whining noise even if the ac is off. it makes that noise the whole time the car is running
The A/C compressor constantly turns because the pulley is connected into the serpentine system. The whining noise is pretty indicative of a low charge in the A/C system. I would start by having your A/C pressure checked and charged if needed.
Jul 03, 2009 | 1998 Cadillac Seville
Compressor will not stay on
do you know if the fans are running constantly? and if so when the compressor comes on it trips out and the fan remains constant? i would like to know the running amps are they correct.
Jun 08, 2009 | Heating & Cooling
Constantly running
follow the wires from compressor to contactor or relay contacts stuck replace
May 24, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Oct 13, 2007 | Refrigerators
Heating & Cooling Logo
196 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
