Noisy fan - Computers & Internet
    Genius:
  • 1,288 Answers
Assume you are referring to a laptop and not a PC?
If it is a laptop, and the fan keeps coming on regularly, it is a sign that the laptop is getting hot. This is usually caused by dust build up in the cooling matrix or around the fan blades and will necessitate it being partially stripped to clean it out, post the laptop model and I'll guide you through this.
If the laptop is cool underneath, then the fan bearing may be going and you might need to replace the heatsink and fan assembly (unlikely)
If it is a PC, then it could be the CPU fan or the PSU fan. If the former, the heatsink and fan assembly will need replacing as the bearing is on its way out, if the noise is coming from the PSU, then you may also need to replace the unit for similar reasons
Posted on May 29, 2011
How to fix a noisy evaporator fan in a frost free refrigerator
The ice usually makes a fan noisy by filling the cavity it needs to move the blades in. check if this is the case, if there is no obstruction and the fan motor itself is noisy it needs to be replaced or serviced, servicing parts is trickier to find than the little motor it self.
To clear the ice just let the fridge stand for a few hours and to help the process speed up you can spray the evaporator with luke warm water.
Feb 26, 2015 | Frigidaire Refrigerators
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
Noisy fan on n6010 life book
fujtsu lifebook's tend to have a noisy fan
Dec 20, 2011 | Fujitsu LifeBook N6010 Notebook
How do I fix a noisy fan for a 2008 Altima.
You will probably have to replace a noisy fan. Trying to fix a noisy fan will can tricky.
Jan 26, 2011 | Nissan Altima Cars & Trucks
Creda Cordialle fan assisted oven is so noisy what can I do?
If it is the fan that is noisy, check for loose fan or the fan blades catching the cover, if all o/k, then it will probably be a worn fan bearing, only solution would be to replace the fan motor.
Nov 07, 2010 | Hotpoint Ovens
Noisy evaporator fan
A noisy fan is caused by several things. The fan can have the blade touching something behind the shroud (the back wall in front of the fan). It could be the bearings on the fan are no good - try oiling with Triflow oil. The fan blade could be out of balance. Try cleaning any dirt or grime off the blade. Fans are cheap (relatively). Tried a new one?
Some fans are just noisy. Try thin rubber between the fan and the screws that mount it (bicycle tire patches work good for this).
Mar 28, 2010 | Kenmore Refrigerators
Fan has become noisy. Does the fan need to be cleaned? Can I take it apart to vacuum the inside?
if the fan is noisy it can be two dirt or grit affecting the propeller or the baring on the motor shaft
Aug 23, 2009 | Honeywell Dryers
Noisy fan in Smeg oven SA398X
Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
Apr 18, 2009 | GE JGRP17 Gas Single Oven
Noisy fan
I believe your laptop needs to be serviced. if you see dust and fluff, it might damage the fan and would need replacement
Mar 05, 2009 | Acer Aspire 4315-2963 Notebook
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
