Question about Keurig Ultra In Home Single Cup Brewer with 54 KCups
The power switch does not turn on the Keurig Coffee maker. I check the power at the plug. It seems as if the switch is not working.
SOURCE: keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
Posted on Mar 02, 2009
  • 85 Answers
SOURCE: Coffee maker doesn't turn on when you flip the switch.
Hello evc622,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, evc. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 09, 2009
cmccune04
  • 213 Answers
SOURCE: Missing Keurig part
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 13, 2010
cmccune04
  • 213 Answers
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
Posted on Apr 14, 2010
SOURCE: blinking lights
let it blink for about 15 minutes, then adjust each one of the settings, then turn it off and back on, for some reason it stops flashing and will work. Warning, after doing this for about a week, mine now has no power at all. It is plugged in and the outlet works and there is no power going to the machine, it is not even a year old!
Posted on Aug 15, 2010
Power switch doesn't work.
The handle is not making full contact and it will not signal the next phase to start.
Jan 28, 2013 | Keurig B70 Coffee Maker
The Kuerig coffee maker will not start. I have checked fuses, used plugs which other appliances work well on and nothing! It was working fine yesterday
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 08, 2011 | Keurig B60 Coffee Maker
The machine was working perfect. This morning there was no power light on and nothing is working. Checked the plug and it works with other appliance. .
heatman101
Jul 14, 2011 | Keurig Elite B40 Coffee Maker
I've had the Keurig B60 about 6 months. It has worked fine until yesterday, when the power went out and will not turn back on. I checked the breaker and switched outlets, to no avail. The power just...
heatman101
Jun 25, 2011 | Keurig B60 Coffee Maker
The keurig is plugged in and will not turn on. there is power at the outlet. When i trigger the switch in the back of the machine nothing happens. Is there an internal fuse?
heatman101
Jun 14, 2011 | Keurig B60 Coffee Maker
My Keurig coffee maker is only making 1/4 of a cup. It drips very slowly and doesn't seem to have the sound of a powerful steaming sensation.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 02, 2011 | Keurig Elite B40 Coffee Maker
Stuck in Not Ready mode Keurig b70
1.) Check if the sensor within your coffee maker is clean... Clean the unit before you use it...
2.) Restart the unit by turning it off... Pulling the plug from the power outlet...
3.) If problem still persist... Have it be check for warranty purposes...
Oct 09, 2010 | Keurig B70 Coffee Maker
Keurig coffee machine model B77 coffee maker will not turn on
Mine will not either. Yesterday it worked just fine now it's as if it is not plugged in. I checked the outlet, it's not that.
Jul 28, 2010 | Keurig B70 Coffee Maker
Keurig Ultra In Home Single Cup Brewer with 54 KCups Logo
374 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
