Question about Keurig B66 3-Cup Coffee Maker
Our Keurig has become tempremental. Sometimes it works fine, but lately it pulls in the water from the reservoir, then only a slight drizzle pours out, not filling the cup. Sometimes it does not pour out at all. There is no descale message. I purchased a cleaner, but it did not help.
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 05, 2011
How do I empty the water from the main reservoir?
  • Turn off the Keurig coffee maker, and unplug the power cord. Allow the unit to cool for 30 minutes before emptying the water. This gives the water inside the hot water tank an opportunity to cool, helping to prevent accidental scalding when emptying.
  • Pull the lid off the top of the water reservoir. Lift the water reservoir straight up and to the right of the coffee maker. Pour out any remaining water in the reservoir into the sink.
  • Turn the small thumb screw on the back of the Keurig coffee maker counterclockwise with your fingers, and pull off the rear access panel. If the screw is too tight to turn with your fingers, use a flat-head screwdriver to turn the screw. Once you remove the access panel, a tube with a plug on the end is visible. Pull the tube out of the plastic clip holder.
  • Place a large pitcher behind the coffee maker. Hold the end of the tube over the pitcher, and pull the plug out of the tube. Allow the water to drain into the pitcher. If necessary, maneuver the coffee maker to the edge of the counter, and hold the pitcher alongside the counter with the top at counter level.
  • Push the plug back into the end of the tube once no more water drains from the hot water tank. Empty the pitcher of water into the sink, and push the tube back into the plastic clip holder. Position the back access panel onto the coffee maker and secure with the thumb screw knob.
  • How to Empty the Water Reservoir on Keurig Coffee Maker eHow
    Apr 08, 2015 | Keurig B60 Coffee Maker
    Keurig B70 automatically pumps water when turned on
    Purge and Descale unit to reset the system to original state.
    Jun 26, 2012 | Keurig Platinum B70 Coffee Maker
    Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
    heatman101
    Feb 02, 2011 | Keurig B70 Coffee Maker
    Water pouring out the vent back into the reservoir...
    i have a water problem but mine is .. when i turn the machine on it just starts pouring water out and does not stop.. and the machine still says not ready all the time the water is pouring out.. anybody know how to fix this ??
    Jun 20, 2010 | Keurig Elite B40 Coffee Maker
    B60.Coffee maker was working fine untill yesterday, now brews 1 cup and pump starts but does not pump and machine shuts off. Help me. Bill Cobb
    Hi Bill, sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up from your water. Do you use regular tap water or filter it in any manner?
    Have you ever cleaned the insides with vinegar? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
    Empty any remaining vinegar from the reservoir and then cycle at least two full reservoirs of water through to flush the vinegar out. When you stop smelling vinegar in your coffee cup, you’ll know when there’s no vinegar left inside.
    You should probably clean you Keurig once a year, or more depending on how heavily you use it.
    SWMBO tells me you’ll find similar instructions above in the Owners Manual or you can check out this link: http://www.ehow.com/how_4927372_clean-keurig-coffee-machine.html
    Good Luck, I hope this helps! – Howard, Burke, VA
    If this solution has been helpful, please rate it, thanks! - hslincoln
    Dec 09, 2009 | Keurig B60 Coffee Maker
    Love my Keurig B60. Bought the B70 with lager cup
    You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
    Dec 08, 2009 | Keurig B60 Coffee Maker
    How do you drain a Keurig b40 coffee maker?
    Empty the water reservoir and put back on the side of the Kurig. Put your hand in the reservoir and slide the disc that monitors the water level back toward the top and and hold in that position,the machine will think there is water. Then put a cup under the head and select a cup. The water will come out. You must hold the disc up inside the reservoir to continue to get the water out.
    Nov 08, 2009 | Keurig Elite B40 Coffee Maker
    The add water light stays on not matter how much water is in the reservoir
    lot of time you have a magnet in the water tank fill it with water and gently tap the side of machine the magnet is block or jam on empty
    THANKS FOR USING FIXYA
    PIERRE
    Feb 24, 2008 | Keurig Elite B40 Coffee Maker
    Keurig B66 3-Cup Coffee Maker Logo
    240 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Oloyede Monsuru
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
