Question about Vizio VR2 Remote Control
How do I take apart the Vizio VR2 Remote Control?
How do you set up screen size on the control?
get to the on screen menu and scroll around till you find aspect ratio alter that to the screen size that fits --ok -then exit
Sep 24, 2015 | Vizio VR2 Remote Control
I am searching for the codes and instuctions on how to set up my magnovox dvd player to my vizio E470VL remote control
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Apr 28, 2014 | Vizio VR2 Remote Control
REMOTE HAS STOPPED WORKING, HAVE REPLACED BATTERIES, BUT STILL NOT WORKING
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 04, 2014 | Vizio VR2 Remote Control
Vr2 has no enter button?
If so, what we can do? Nothing can be done.
May 11, 2013 | Vizio VR2 Remote Control
No enter button
Use OK button if there it is.
Reset vizio tv
Unplug the TV from AC mains wall socket, and re-plug it back after 5 minutes or so. This must make it a hard reset. There is no other procedure.
Mar 30, 2013 | Vizio VR2 Remote Control
Find my Vizio remote
Contact the authorized service center for Vizio. There is no other way.
Aug 30, 2012 | Vizio VR2 Remote Control
Codigo de RCA para vizio
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Pull up older posts there
May 15, 2012 | Vizio VR2 Remote Control
I need to manually program my universal vizio remote
1. Manually turn on the VCR/DVD/Cable set top box.
2. Press the VCR/DVD/Cable set top box button on the remote control.
3. Press and hold the SETUP button until the LED LIGHT flashes twice.
4. Enter the codes using the Number Buttons. If the code is accepted, the LED flashes twice after the last digit is entered.
If the LED does not flash twice, repeat Steps 2 through 4 with the next code listed for the component and
manufacturer.
5. Point the remote control at the VCR and press the POWER button. The VCR/DVD/Cable set top box will turn off.
6.Your are done.
Thanx
Jul 23, 2010 | Vizio VR2 Remote Control
I spilled water on it and now it won't work. Is there anything I can do to revive it?
Take the remote aparts,clean it really well,take a hair dry put it on low heat dry PCB board,should work after this,not than it dead,it garbage.Try website like Remotes.com to buy an exact remote.
Jun 21, 2010 | Vizio VR2 Remote Control
Vizio VR2 Remote Control Logo
393 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
