Question about Mtd Garden
4 cycle trimmer cuts out when given gas - Mtd Garden
  • Mtd Master
  • 7,482 Answers
Hi rynbergm...
Sounds like you have dirt/debris in your carburetor jets or fuel passages
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 31, 2011
How do I adjust the float to get more gas. bring the float up higher or lower the the float?
Lowering the float allows the fuel to enter. As the float rises, the needle valve is depressed, cutting off the fuel.
Mar 09, 2015 | Craftsman WeedWacker Gas Trimmer 29cc...
Why does my ryobi trimmer smoke badly while cutting
If it's a four cycle engine, you probably have too much oil in it or your holding it with the carburetor down. If it's a two cycle, you probably have too much oil mixed with the gas.
Aug 09, 2014 | Ryobi Garden
Trimmer keeps cutting off
change spark plug or like mine it my only use non-e85 gas
Mar 30, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Homelite whipper snipper amnyal needed. I need to know the size of the cutting cord or citting line size and the fuel mix for the homlite whipper snipper model HBC265JSNB SN1008015039 LwA N197 are all...
This Homelite gas trimmer runs on a 50:1 mix of unleaded automobile gasoline and two-cycle engine oil. That is equivalent to 2.6 fluid ounces (80 ml.) of oil to one gallon of gasoline or 4 tsp. (20 ml.) of oil per quart of gas, or 2 tsp. (10 ml.) of oil per pint of gas. Don't use automotive motor oil or two-cycle outboard motor oil in your Homelite gas trimmer; they contain additives detrimental to trimmer performance. Use mixed fuel within 30 days.
Feb 07, 2018 | Garden
Renewing the cutting line
This product is driving me nuts - if someone can't help then its going into the bin
Aug 28, 2008 | Poulan 25cc 2-Cycle Gas Powered String...
Garden Logo
67 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
