Question about GARDENA Water Timer #31169-4
I Got some problem with My gardena T120 in fact the junction piece was broken, I would like to find replace it. D Could you help me. I m located in France. I buy it in Castorama Antibes last year but they are not able to help me and ordering the piece. Tahnks for your HELP
The problem that my 1060 plus always gets is the big diaphragm wearing. The water does not turn on. This fixes it at the cost of about a pound from my local stockist:
296649 SPARE: Gardena Water Timer# 11
Posted on Feb 05, 2014
Some Gardena resources appear on following page, including Gardena link for parts.
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
Add a comment and say where you were able to buy parts, since others are also asking for parts.
And also say how you were able to repair the water timer.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 29, 2011
  • GARDENA Master
  • 5,245 Answers
There are no parts for these timers
Open following link for Gardena timer manuals
Posted on May 25, 2012
Gardena t120 sprinkler is blocked - can I dissemble it and clean it out?
The end should unscrew. Then attach the hose to blow out any dirt. The individual holes might also need to be unplugged with a wire
Jun 21, 2014 | Garden
When is ON the timer admit a water jet and after that the valve is closing even if the battery is full, the timer ON and the supply of water open. Thanks
Problem is not clear and timer not identified.
Open following link for Gardena resources including contact information for Gardena.
If timer is cracked, then electric parts can get wet and stop working.
If timer valve is not closing, maybe the timer is broken or something is stuck in the valve.
Add a comment for more help
Upvote the help.
Also take advantage of fixya expert assistance live.
Jun 09, 2011 | GARDENA Water Timer
We set the timer and the battery is fine. When we turn on the faucet the water runs through the timer non stop
Hi Karen,
Fixya promises a fix, but some things are broken and can't be fixed.
I suspect that is the case here.
Sounds like the water valve might be stuck open.
Or the battery contacts are bad, a wire is broken, the clock motor has worn out, the internal on-off switch has worn out, electrical short, a piece of plastic has broken, a rubber gasket is broken or twisted in the way, sediment or minerals have built up in the valve. Or a combination of factors above.
Leaving valve exposed to freezing temperatures will crack the plastic.
Clean the waterway with CLR calcium lime rust and see if problem is solved, but immersing valve in CLR solution will not be good for electrical components.
I have not read any internet post where somebody says they repaired a water timer after timer has gone bad. This is true for all brands. I am looking for that information, and actively seeking factual accounts.
Since many other people have problems with Gardena valves, add a comment and say what you did to fix problem so everybody finding this link can share your solution.
Open following link below for some Gardena resources, including link to parts.
I do not know what parts to suggest, nor do I believe part replacement will solve problem.
I can't find sellers of Gardena parts, and the Gardena contact-us page doesn't respond back as of right now, but things are continually changing and folks visiting this link can update the post with their solutions, and add links to sellers of parts that would be of value.
Generally speaking, except for some timers from Intermatic, Paragon and Tork, there are no replacement parts for timers.
I am not sure what manufacturer makes the timer mechanism for Gardena.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
May 15, 2011 | GARDENA Water Timer
Frost cracked housing, are spare PBT-GF20 AVAILABLE
Open following link for some Gardena resources, including manual and link to gardena site.
Gardena certainly has a glossy site, but I have been unsuccessful trying to contact the company.
Their products come with warranty and they show parts, but no hint where you can buy parts.
If frost crack the device, then it means the whole device was pushed out of shape until something broke. Frankly, I would not spend money trying to fix a cracked piece of plastic.
Apr 23, 2011 | GARDENA Water Timer
How do you get into the Gardena T120
To access the Gardena T120 diaphragm remove the oval cover at back with small flat screwdrivers to reveal the round retaining cover. The retaining cover unscrews to reveal the diaphram mechanism which can be removed and cleaned. Hopefully this solves the problem.
Dirt or sludge in here cause the timer to stay on or leak.
Stage 2 if the above fails.
Remove the front timer cover with very large flat screwdriver. Simply lever off the front timer cover. This is a brute strength operation. There is no tab or button to help remove the front. Insects and dirt can get in and stop the operation of the needle mechanism.
Stage 3
I do not know how to get to the mechanical timer itself. Any suggestions?
Nov 24, 2010 | GARDENA Water Timer
Where can i get a replacement diaphragm for my Gardena Water Timer #31169-4? (ideally NZ or Aus source)
oct 2110
I cannot find parts or manuals on Gardena products.
Gardena.com has a product page and a contact page
They have technical drawings for some products so parts must exist somewhere.
Gardena product page
Contact Gardena
If you are looking for operation manual at Gardena, they only have sales brochures and technical drawings.
Oct 26, 2010 | GARDENA Water Timer #31169-4
I have a Gardena Water Timer T 120 that no longer works. It has a lifetime guarantee...but where do you send them to get the repair or replacement?
oct 2110
Gardena.com
Contact Gardena
If you are looking for a manual at Gardena, they only have sales brochures and technical drawings, neither of which helps the ordinary customer.
JUST FOUND OUT THE SPEEDO CABLE IS IN TWO SECTIONS, ONE TO TRANS, ONE TO SPEEDO HEAD. THE SECTION TO TRANS IS BROKEN AND I WAS WONDERING WHERE THE JUNCTION BLOCK OR BRIDGE OR WHATEVER IS USED TO HOOK THESE...
if not see junction under hood then it would be under dash area? can pull steering colum down just 4 bolts then have room to check out tom b.
Jul 28, 2008 | 1990 Mazda 323
GARDENA  Water Timer #31169-4 Logo
442 people viewed this question
Top GARDENA Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Bill Boyd
Are you a GARDENA Hardware and Accessory Expert? Answer questions, earn points and help others
