Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
I bought a cusinart dgb 50bkc and the same is not working. i followed everything on the manual but it still fails to make coffee. can someone help
  • 2 more comments
  • priyaat May 31, 2011
    I just bought it on 27th May in Toronto and I straight away brought it to India.
    I followed all instructions as mentioned in the manual.
    The water is filled. The model is DGB 550BKC.
    It grinds and after that it stops.
    When I put the grind off button and then click the machine on - everything stops !
    The unit is just not doing anything, it is not heating, it is not brewing, it is only grinding and doing nothing else.
    I just bought it on 28th May 2011 from a Future Shop in Brampton, ON, Canada and I straight away brought it to India. I followed all instructions as mentioned in the manual.
    Hope you will be able to help me make this machine work.
  • priyaat Jun 01, 2011
    which means u have no solution as to why this is not working ?
    I have not recd a feedback which could help me resolve.
    Guru:
  • 1,833 Answers
What is the problem you have faced exactly with your coffee machine? If you can't turn it on then check the power cable and your electric outlet and also check that you have plugged it properly. If the machine get turn on but you can't brew a coffee then remove the infuser and thoroughly clean it. Then Repeat the operation using a maximum of 1 measure of ground coffee. May be the holes in the spouts are clogged. Scrape the holes with a needle. Make clean the brewer. And also Descale the machine. If it doesn't solve your problem then you have to repair your brewer.
Posted on Jun 01, 2011
    President:
  • 1,335 Answers
This sounds like you have a dead unit. I had a failure with my coffee maker shortly after I purchased it and had to send it to the repair center (phone number in back of manual) for a replacement under warrantee. Call the repair center to get an RMA number before you send it in to avoid problems.
My replacement unit has been in service for over a year brewing coffee twice a day.
Let me know if you have any other questions.
Posted on May 31, 2011
  • Robert Kitaji Jun 01, 2011
    The controller needs to be replaced. Cuisinart does not sell parts for self repair, but has units returned to its repair center for fixing. Since you are in India, your best bet is to contact Cuisinart by email on their international customer care on www.cuisinart.com
  • 1,998 Answers
So what is the unit doing when you put the water in the unit the unit then heats the water if the water is not heating then the unit will usually stop and not go any further also how old is the unit? when is the last time the unit was cleaned? what is the setting of the grind that you are useing all these questions have to be answered in order to further diagnose your situation I await your reply Thanks Rick
  • Rick Ead
    Rick Ead May 31, 2011
    first of all there is a three year limited warranty on that unit so you wouldnt be able to take the unit apart and do any repairs to it or you would void your warranty.secondly depending on where you bought the unit you would have to contact them to find out about there warranty service seeing how you are now located in india and how abouts they want to go about repairing the unit.Once again do not try to take this unit apart or if you do as the preverbial saying goes you own it all which means labor,parts everything you would have to pay for where as most likely your looking at having to ship the unit to them to have it repaired also if you have highly calcified water where you are currently at the unit will not heat enough to cause the dripping cycle to operate and most likely your looking at sending the one you have back when your new one arrives is the way i see how they do things there and btw there customer service is rated as 5 stars so open that manual and you will see there customer service number and give them a call if you have any further questions message me back I await your reply Thanks Rick
  • Rick Ead
    Rick Ead Jun 01, 2011
    yes i do have a reason why your unit is not working listed in the last paragraph do you happen to know the hardness levl of the water this is right out of the service manual as to hardness level with that machine " if you have highly calcified water where you are currently at the unit will not heat enough to cause the dripping cycle to operate"
I just purchased a DGB-900BC unit. Coffee temperature is really not hot.
See page 10 of your user's manual; if you misplaced it, go to:
Cuisinart DGB 900BC Instruction Booklet Page 10
If the instructions listed half-way down the page don't help, contact Cuisinart customer support, or return the coffee maker to the store you bought it from.
Feb 21, 2017 | Coffee Makers & Espresso Machines
I need a manual for a cuisinart coffee maker - older model
If you go to Manualsonline.com and start clicking on Kitchen Appliances>Coffee Maker>Cusinart Kitchen Appliances>Cusinart Coffee Maker. Then you can choose your type and download the manual free. Or an easier way is once you are in Manualsonline.com Click on Brand > see all>Cusinart>kitchen appliances> Coffee maker>your type. Download the maanual free. I hope this will make your search easier. Kolbrun
Nov 02, 2013 | Cuisinart Coffee Makers & Espresso...
Coffee maker wont stay on after making a pot of coffee help
i downloaded the owners manual at http://www.cuisinartwebstore.com/detail/CUI+DGB-300BK
and resolved it by reading the manual. ( i had lost my original )
May 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cusinart DGB 550BK coffee maker not working properly
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart Coffeemakers
Need help using my coffee maker
Thank you for note I went on Cusinart site and found a copy of the manual and got my coffeemaker to work.
Dec 25, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
NEED oWNERS mANUAL FOR gRIND & bREW SO i CAN SET IT
if you go to this address you can download a manual...
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DGB-300BK-_E
if the address doesn't go just go to safemanuals.com and in drop boxes choose cuisinart/dgb-300bk. will take you to thie page.
enjoy your coffee.
Dec 02, 2008 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
DGB-300
Definitely do the vinegar/water cleaning. It will almost undoubtedly resolve your issue.
Nov 22, 2008 | Cuisinart DGB-300 Coffee Maker
DGB-600 Will no longer grind coffee
I am having the same problem, can someone please help?
Oct 09, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
114 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
