Question about Hampton Bay HBLG5004 Air Conditioner
Does a air conditioning wall unit take freon - Hampton Bay HBLG5004 Air Conditioner
How do i recharge freon for me Friedrich KM18J30A-3 window unit?
only a certified HVAC technician has the license to carry and use the freon used in home A/C units. it's not like the car units we can do ourselves.
Jul 14, 2012 | Friedrich QuietMaster KM18L30 Wall/Window...
My ice maker is not making ice. I have water to the valve located near the bottom back of the machine. It doesent appear to be getting through the valve and up to the ice maker. Also, when I moved the unit...
ur fridge might have run out of freon gas since the line that runs thru the valve was detached. the freon gas might have evaporated so there is a need to charge ur unit with new freon. this can be done by an ref and air conditioning technician.
Jul 08, 2011 | Refrigerators
My Amanda wall unit keeps freezing up. Cleaned filter and coils, please advise. Thanks, Gilbert
If a AC unit starts to freeze up, then that is a sure sign that it is low on freon. A wall unit is harder to add freon to since those units generally do not have Shrader valves to purge or add freon. It is sort of like your refridgerator in that the freon is sealed in the factory and to add , a technician has to cut the evaporator tube and add a valve, then add freon, pinch the tube off and seal it once the correct pressure is adjusted.
I would say that somehow your unit has developed a leak, and will get worse.
see:http://real-estate-agents.com/tips/hvac/maintain-air-conditioner/
Jan 23, 2011 | Amana PTC123B35AE Air Conditioner
Fedders air conditioning model a3t12f2ag , my unit runs fine but it will not blow cool air?
you either have internal thermostat problems, selector switch problems or youve got a freon leak. to determine a freon leak is the units coil freezing up or is it dirty check filter first take unit out and to car wash remove housing and give it a bath dont plug it back in until its dry.hope this fix works if not work your switches remember they set in one position most all the time if freon call a tech
Jun 18, 2010 | Fedders A6D24E7D Wall/Window Air...
After 4-5 hrs of running it ice particals drop out of AC and fall out.
MAKE SURE THE FILTER IS CLEAN AND COLD COIL IS CLEAN . JUST REMEMBER 70 OUT SIDE AND 70 OR LOWER INSIDE AND YOU HAVE A ICE CONDITION. 75 INSIDE AND 75 OR HIGHER OUTSIDE KEEPS UNIT FROM ICING UP. IF ITS LOW ON FREON IT WILL ALSO ICE UP. MOST OF THE TIME THEY DONT LEAK FREON BECAUSE THEY ARE SEALED SYSTEMS
Apr 23, 2010 | LG Art Cool LA121CNP wall/window Air...
How to add Freon R407C to a ductless air conditioning unit
If you are not trained to at least charge a unit U will in the end do more harm than good get the proper service. what makes U think U need freon could just be dirty? Tom
Jul 10, 2009 | Heating & Cooling
Punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Nov 09, 2008 | Maytag M7Y15F2A Air Conditioner
Heating & Cooling Logo
56 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
