Question about Garden
Partner b322 strimmer 1998. Husqvarna motor. Walbro WT-300A carb.Engine will not start/run.Clean tank,new fuel,correct mixture.No fuel leaks.Fuel runs freely out of fuel pipe.New plug,correct gap,good spark.Lever operates butterfly.Motor will run on squirt of easy start for couple of seconds.Motor will run if spray fuel into carb intake. Dismantled carb no vislble defect. Reassembled carb same problem.Please help.
smartr10U
  • 1305 Answers
SOURCE: Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Posted on Jul 23, 2009
trippssmengi
  • 76 Answers
SOURCE: tecumseh 9hp craftsman snowblower will not stay running
First take the carb off of the engine and then remove the bowl, carefully take the float off paying special attention to the needle and how it is attached to the float. Next, lightly blow air into the fuel inlet while holding your finger over the spot where the needle goes in. Use a bread tie with the paper scraped off. Stick the wire through the pick up tube at the bottom of the carb. Find any other holes and probe those holes with the wire. Then thoroughly wash the entire carb with carb cleaner then blow the whole carb off. Then put the float and needle back in making sure that when putting the bowl back on that it seats tightly all the way around the rubber gasket. Also, just before you put the bowl on turn the carb upside down to see if the float is sitting level. If it is put the bowl on, If not then the spot where the needle sits on the float has to be bent one way or the other just a little until the float sits level. After the bowl is put in place, the nut that holds the bowl on the threaded area should have two possibly three holes plus the hole down the center, probe all holes with the wire. put everything back on the motor and try again. If it still won't run then you will need a carb kit.
Posted on Dec 27, 2008
KMusselmann
  • 247 Answers
SOURCE: Champion Vantage 35 - mower will not keep running
More than likely the jet in the carb is somewhat clogged. Did this just happen after sitting for the winter? If so, start the mower and when it starts to die pump the primer to keep it running. Sometimes it will clean itself in a few minutes. If not, carb cleaner or take the carb bowl off and clean the jet.
Hope this helps
Kurt
Pls rate the answer
Posted on Mar 20, 2009
  • 376 Answers
SOURCE: not getting enough gas to the carb have to run choke 3/4 engaged
Sounds like a restriction in your carb, not getting enough gas. I would clean out the carb again.
Posted on May 23, 2009
backwoodsctr
  • 169 Answers
SOURCE: DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Posted on Nov 30, 2009
Why won't it idle without choke?
Fuel supply problem somewhere. How is the float adjustment and the float valve? I'd guess the level adjustment is too low.
Mar 28, 2015 | Honda 2005 TRX 400EX
Walbro wt-141 changeover to wt-629
If the carb has two connections then it is designed to work with a primer bulb, the fuel inlet will be nearest to the pump cover, the alluminium cover held with a single central screw, you can either get the correct carb for the machine or use a short rubber tube with a blank in the end ti close it off.
Feb 02, 2013 | Poulan Weedeater Carburetor - Walbro...
My husqvarna 122c starts fine with the choke on. When the choke is turned off, the motor revs very high then eventually dies. If I feather the press the throttle, it dies right away? carb issues?
This is classic fuel starvation, replace the fuel filter in the tank, check the fuel hoses from the tank to the carb for signs of leaking or slits and cracks, failing that you may need to adjust the fuel mixture, there is a special tool to adjust the mixture screws, part no. 530035560 ( try the web for sellers ) once you have the tool unscrew the H screw 1/4 turn to adjust the upper fuel supply.
Oct 24, 2011 | Garden
Husqvarna 20" 359 wont start. Has spark. the gas and oil were mixed and left in a plastic vented can in the hot sun. came back a day later and half the mixture evaported. Could the gas have evaporated and...
You are correct. Too high a fuel to oil ratio will not asallow the engine to run. Try using a fresh mixture of the correct ratio. It may take a lot of pulls on the starter until the old fuel is purged from the carby.
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
Flooding walbro carb from blower.
The problem centers around the carburetor. The question lies in the condition and operation of the carb initially.
It appears you may need to double check your assembly of diaphragms and gaskets. check for loose welch plugs, adjustment needles in the wrong holes, inlet needle set too high.
*note: metering side diaphragm goes on top of the gasket, fuel pump diahragm has the gasket on top of it.
Nov 10, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
1,477 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
