Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
I have a pac ct90 9000 btus and it is leaking water from the bottom..what could be causing it? it just started doing this..
Fisher and Paykel twin dishdrawer
there is water in the base setting off the flood sensor, you will need to remove the bottom draw and dry the water up with a towel (make sure the power is off and unplug it from the power point) then you will need to do a bit of testing to locate the cause of the leak, if your lucky the leak was caused by incorrect dish stacking or something too big in the draw
Jan 02, 2017 | Fisher and Paykel Dishwashers
I have a DeLonghi air conditioner model # PAC A110L that is leaking water from the bottom of it. I lost the manual (ofcourse) and I need to know who to fix this issue. THanks! :)
its condensation,which is normal,try tilting the unit back a little so that the water can get to the drain hole in the back of unit.
Jun 05, 2010 | Heating & Cooling
REPLACED COIL PAC RUNS ROUGH
ROUGH IDLING CAN BE CAUSED BY VACUUM LEAKS.LIKE THE INTAKE MANIFOLD GASKET.OR VACUUM LEAKS FROM HOSES.LOW COMPRESSION CYLINDERS WITH BAD VALVES.LEAKING EGR VALVE GASKET.DIRTY CLOGGED FUEL INJECTORS WILL CAUSE ROUGH IDLING.
Jan 17, 2010 | 2002 Kia Optima
Leaking
Please check the water container for leaks. Normally,
it does not leak, since the water is supposed to evapo-
rate due to compressor heat. The water that the aircon produces goes to a containing pond near the compressor. So that if there is a leak, it emanate from
this area. May this tip help you.
Jan 10, 2010 | DeLonghi PAC C100 Air Conditioner
I have a Delonghi PAC A120LE air conditioner that leaks water. How do I stop or divert outside? I noticed there is a drain on the back - should I put a hose on that?
OK. This fixed my A120LE from leaking. First unplug the machine for safety. If you are looking at the back of the unit you need to take off the right side panel. I took off the all the panels but you could just take off the right side.
There is a reservoir on the top that collects condensation from the top coil. (shown in the circle) The drain hole on mine was clogged. If you stick a small screwdriver or paperclip in the hole to push the debris through it should start working properly again. I did this to mine yesterday and it hasn't leaked since!! Drain hole is shown here in close up picture. Unclogging this will allow the condensation to flow down to the main reservoir on the bottom where it will be evaporated in the AC exhaust.
Aug 19, 2009 | Heating & Cooling
How do we get rid of the water that collects in
There is no container, it burns it up inside into hot air and sends the moisture out the exhaust tube which you hooked up to the back of the unit and ran either outside or underneath house through flooring. There is one of these units that does come with a bucket in the front bottom drawer that comes out, but if its a PAC ct90 just like mine, there is no water empty it handles all that itself.
Aug 04, 2009 | DeLonghi PAC T110P Portable Air...
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Jul 31, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Heating & Cooling Logo
709 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
