Question about Broderbund PrintMaster Platinum
I have Print Master Platinum 10 and my Windows operating system is Windows 7 are they compatiable? I tried installing the program but it doesn't install. Is this program too old for this operating system?
  • 36 Answers
I don't think Printer Master Platinum 10 will run on Windows 7. However, solution #3 on this page (http://www.fixya.com/support/t2129564-printmaster_platinum_10_version_will_not) references how to make it run on Windows Vista. The same is true for Windows 7. You can run almost any software in compatibility mode. Since they're up to version 18, I doubt it will work with Windows 7.
Hope this helps.
Posted on May 29, 2011
How to install Print Master Platinum 17 on windows 10
You can't!
Unfortunately this program is not supported on Microsoft's new operating system Windows 10 as it requires .Net Framework 1.1. There are currently no updates available as Microsoft is no longer supporting .Net Framework 1.1.
So if it says anywhere in the instructions "requires Net Framework 1.1" then it won't run. It was compatible with Windows 7.
Oct 19, 2016 | Computers & Internet
I run win7Pro & AG CreataCard Platinum 8 will not install..is my favorite card making program for family & friends, any help appreciated.
CreataCard Platinum 8 was written for XP and older versions of Windows. Changes in the OS make it difficult/impossible to install.
Do you have the 32-bit or the 64-bit version of Win7Pro? Click Start > Control Panel > System and Security > System. If the title reads Windows 7 Professional x64, it's the 64-bit version. (If it doesn't end with the x64, you have the 32-bit version.)
In any case, the best option is to try running an older version of Windows on another machine, a dual boot system or a virtual computer. With the Pro version of Win7, you can run a virtual XP for free (if your hardware can support it). Download and install Virtual PC and the XP mode package from Microsoft. (You'll need to set aside some memory for the virtual PC to run.) Then install CreataCard when running XP mode as if this is your only computer.
The only real problem is that you will not be able to have hardware installed on the virtual XP and the Windows 7 real machine at the same time. (So you can't share a printer.) Also, to share files between the two "systems", you will need to save them to external media (flash drive or optical disc, for example). Your motherboard and CPU need to support Virtualization. You have to turn this on in your BIOS on some systems. (Press Esc, F1, F2 or F10 repeatedly depending on your system right after turning on the system. If you miss the timing, shut down the computer and then retry.)
Other virtualization programs are Parallels and VMWare. However, with those programs and the other possible options for running CreataCard, you need a licensed version of the older version of Windows.
If you have the 32-bit version of Windows, you can try the Compatibility Mode. (Right click on the installer and choose Properties. Then click on the Compatibility tab and select Run the program as compatible with an older version of Windows. Apply the changes and click OK. Then right click on the installer again and choose Run As Administrator.) You may have to repeat this on the program icon after installing. However, the compatibility mode doesn't always work even if you have the 32-bit OS (and thus don't need the signed driver).
An alternative is to upgrade your software to one that is Win7 compatible. I'm not sure which of these Broderbund design and print products are most similar to CreataCard: http://www.broderbund.com/c-6-design-print.aspx . However, you will probably not be able to open old documents.
I hope this helps.
(XP mode is available with Win7Pro and Ultimate. At my house, we have two computers with Win7Pro with one running XP mode. At least once, the virtualization was turned off during a BIOS update and XP mode failed until the setting was corrected.)
Dec 24, 2011 | Broderbund American Greetings Creatacard...
I have Windows 7 and my Print Master 16 doesn't seem to work now
Printemaster 16 is not compatible with Windows Vista or Windows 7. You will need to upgrade the software.
Jul 11, 2011 | Broderbund PrintMaster Platinum 16
Windows 7 Professional + compatibility with Broderbund Print Master Platinum Version 18
If a program cannot be run under Windows 7 because of compatibility issues, which is the case with Broderbund Print Master Platinum Version 18, you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Nov 20, 2010 | Broderbund PrintMaster Platinum Version 18
How do I make my Print Master Platinum 16 compatible with Windows 7?
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Oct 29, 2010 | Broderbund PrintMaster Platinum 16
I installed window 7 into my laptop. My printmaster platinum 18 is now not working properly. What can I do to resolve this issue
Right click on the program shortcut click on properties from the menu and click on the compatibility tab , check "Run this program in compatibility mode of windows xx" and select the version of windows in which the program used to run. Apply the settings and open the program again. If the program still doesnt work try to reinstall or get an updated version for windows 7 maybe Print Master 2010.
Sep 12, 2010 | Broderbund PrintMaster Platinum Version 18
Broderbund Print Master Platinum 16 is not compatible with Windows 7
Aug 08, 2010 | Broderbund PrintMaster Platinum 16
Why does print master platinum 18.1 which should be compatible with Windows 7 still not work
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jul 15, 2010 | Broderbund PrintMaster Platinum Version 18
Is print master 16 compatible with windows 7?
(making a program work with windows 7)
May 04, 2010 | Broderbund PrintMaster Platinum 16
Can i install the print master platinum 16 on my new computer with windows 7
ypu cannot use print master platinum 16 with windows 7 or for that matter vista
Mar 05, 2010 | Broderbund PrintMaster Platinum 16
Broderbund PrintMaster Platinum Logo
225 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
