The pin that u put the charger in has went back in the laptop. how to open it to get to it to fix it.
    Problem Solver:
  • 10 Answers
The power socket on a laptop is usually soldered directly to the mainboard. Sometimes the socket is on a seperate smaller daughterboard or on a cable that connects to the mainboard, but usually this is not the case. Opening the laptop to perform this repair can be very trick and time consuming. I would certainly not recommend an amateur attempting this repair as usually the entire board needs to be removed, the socket de-soldered and a new socket soldered in place. Not for the faint hearted! If you wish to provide laptop model details I may be able to provide the screw locations etc and disassembly guide.
Posted on May 29, 2011
My toshiba laptop is completly locked out and i need to get in thead how can i unlock me laptop?
hi...
its bios password.you have to open the laptop.to open laptop see in youtube how to open.just put your model number of laptop in youtube saying how to remove mainboard...after you open ur laptop you will see battery in it and a small jumper with battery trun ur laptop on and remove that small jumper and put it back ... there will be 3 pins..you will remove jumper from 1-2 so put it back in 2-3 ..the laptop will shut down..then put the jumper back to 1-2 ..and trun ur laptop on inshallah the password will go...
hope it solve ur problem...
Jan 19, 2014 | Toshiba Computers & Internet
The ac port in my dell inspiron is broken so the charger pin isn't connecting to it and the laptop wont turn on because the battery is dead and i cant bother to buy a new solder cause im not from
A) You don't want to take the laptop apart.
B) You don't have the money to have it repaired.
C) Keep going like you are with fiddling with it, and you'll smoke the AC adapter (Charger), and Power MOSFET's on the motherboard.
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
What !O_O! sort of 'miracle cure' are you expecting?
If you wish to correctly repair the laptop, this is the place.
Rig it so it works temporarily, and maybe permanently damages it?
Suggest go to another website.
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1545_service%20manual_en-us.pdf
Charger Board
http://www.ebay.com/itm/ORIGINAL-DELL-INSPIRON-1545-DC-POWER-JACK-CHARGER-BOARD-00829-/170995370099?pt=LH_DefaultDomain_0&hash=item27d01e4873
You're going to need one of these, and connect it's alligator clip to a good ground source,
http://www.radioshack.com/product/index.jsp?productId=2103245
Doesn't have to be from that store. It's just an example.
Average cost is $3 to $6.
http://www.insidemylaptop.com/replace-keyboard-dell-inspiron-1545-laptop/
Need guidance? I'm right here. Post back in a Comment.
I'll step by step you through it.
Regards,
joecoolvette
Mar 01, 2013 | Dell Inspiron 15 1545 Notebook
My sony vaio charger is got pulled out one day by kids running around, and when I went to plug it back in it would only work if i have it a certain way. I went out and bought a universal charger that said...
You mentioned that when you plugged in back the charger, it worked if you try moving it right? chances are, the problem could be with the charging pin itself of the laptop. there might be a loosening due to the sudden pulling out of the charger..
Apr 09, 2011 | Sony Vaio PCG 7Z1M Laptop Universal AC...
I put the flashlight on the charging area and the thing went nuts. I unplugged it and plugged it back in and it went dead.
I think I have bad news for you. It sounds to me like you put the flashlight made out of metal, that conducts electricity across the pins of your cordless vacuum cleaner charger and accidentally short circuited the charger and it went poof. Poof is not a good thing. It may be possible, though I doubt it,
that there is a fuse inside the charger that can be replaced. I would check a small appliance repair company as to the cost of fixing this before I gave it to them. I think it would be more expensive than it costs to purchase it. That is, if there is a replaceable fuse. If you can tell me the name and company, I could do a little research myself. I hope this is helpful to you. Let me know if I guessed right about what happened. Thanks.
Best Regards,
Mark
Dec 29, 2010 | Vacuums
My pin on my laptop is lose how can i fix it and my laptop dont turn on
Do you mean the pin where the charger (AC adapter) connects to? If so, this is often difficult to fix. This is possibly why the laptop won't turn on. Can't connect the charger since the connector pin is broken, so no way to charge the battery. This can sometimes be repaired by disassembling the laptop and soldering the connector back into place. If the connector itself is broken then some sort of hack job solution using generic parts canimplemented but the end result will not be very pretty. The bill for such repair jobs usually starts at around $100 & goes up in price.
Feb 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
No power
suspect either dc adapter or dc jack, bad pin. easy fix
Feb 11, 2010 | 3Com Computers & Internet
TOSHIBA M35X-S149????????? charger went inside the computer how do i fix it??? any help will be greatly appriciated
when you say the charger went inside the laptop that the piece that you plug into felll in. You have to open the case, get your soldering iron out and hot. Once you take off the bottom portion of the case you may need to remove the board to get to the plug piece. Once you get there you need to soldier it back on.
Dec 23, 2009 | Toshiba Satellite M35X-S149 Notebook
Doesn't turn on, Red LED light stays lit
Try restoring the blackberry using the blackberry firmware update utility, if the problem persists, it's a logic board issue. there are blackberry repair websites that show you how to do the replacement yourself, otherwise here is a service that can repair any Blackberry Bold, Storm, Pearl, Curve, 8800 for screen, lenses,
track balls, usb ports, waterdamage etc.
The website is: Blackberry Repair
May 31, 2009 | RIM Blackberry Curve 8300
Charger pin broken off
daimese is poware battri
Dec 01, 2008 | Acer Aspire 3680 Laptop
Dead laptop
Does the green light on the charger turn orange when you plug it in? Because it might have been that you didn't actually charge it. The metal ring around the charger tip sometimes gets bent so that it doesn't make good contact. If you aren't getting a constant green or orange light when you plug it in, you might not be charging it at all.
That would be the easy fix. The real problem is probably much greater, because you probably know how to charge your laptop. The laptop doesn't need a battery to run, so if it doesn't start up while plugged in, you have an additional problem.
write back if you find that the simple things didn't work and you need more help figuring out a specific fix.
May 18, 2008 | Apple iBook Mac Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
