Question about Vacuums
Hi there, My mower model No. 944.367501 (158cc, 5.50). I changed the engine oil and a new spark plug in the new season. The gasoline is fresh. The mower worked for 40min and stopped, The engine oil level and the gas are good, and nothing blocked underneath. Now it can start, but only last 5-10 sec then loss power. Would you please give me some clue how to fix it. Thanks in advance.
4 Suggested Answers
  • 105 Answers
SOURCE: will not start
It sounds like your blower needs a carburator overhaul. Either there is gum from dried gas blocking a passage, or one of the diaphrams has a crack in it. This is not a difficult repair. You purchase a carb kit for your machine, then carefully disassemble the carb & clean all of the components with brake cleaner spray. Make sure to spray through the several tiny holes in each diaphragm chamber. Now put the carb back together, using the new parts in the kit.
Before you do this, however, check the hoses on the engine, one might be cracked or blocked.
Posted on Apr 14, 2009
e-Guru
  • 3917 Answers
SOURCE: MTD Yard Machine, 3.5HP /
Have you checked the primers on both of these units? It is possible that the primers are not putting enough fuel into the system. Look for holes or torn edges. Depending on the engine models. Also it can be lack of necessary vacuum and compression in the combustion chamber. But most probably it is a carb issue. It is suggested to rebuild the carburetor. Also when you clean the carburetor make sure the jet screws are seated in proper position in the way when you put the jets back in, you know to lightly seat them first and then turn them back out to their correct position before you started.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 24, 2011
SOURCE: I have a Craftsman Weedwacker
Need to adjust the Carb
Posted on Jun 18, 2011
What could I damage on my boat fuel line? Primer bulb, any filter ... ?
There could be several reasons. I'd first look at stuck floats in the carbs. I believe there's 3 carbs and if all spark plugs are wet all floats are sticking.
But assuming it didn't overheat, and the spark plugs are wet with fuel (as opposed to water) - sometimes a defective coil will short out only when it gets warm (most time they short all the time). They can be tested.
A very good mechanic once told me there are only four things to concentrate on: Suck, Squish, Bang, and Blow. In other words, Fuel delivery, Compression, ignition system/spark, and proper exhaust. My experience has been that I've never had to worry about Blow (knock on wood) with an outboard. Others have however.
Additional advice: The number 1 cause of outboard problems is gas. Todays fuels are great for fuel injected cars but break down sooner than old gas mixtures. Always put a fuel stabilizer in you tank. It's cheap and only takes a few ounces to protect from hundreds of dollars worth of carb work - and avoid sticky floats.
Jul 06, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
B&s engine on mower turned upside down, won't start now.
Take the spark plug out, turn ignition key or pull rope until the engine turns over several times. Let it sit for about 5 or 10 minutes and repeat. Replace the spark plug with a new one. Make sure that your crankcase is not over filled or under filled with oil, and make sure that there is plenty of gasoline in the tank. Make sure that gasoline cap and oil cap are on "securely". Now try to re-start. (The engine may smoke for a while, but it should clear up in a few minutes).
Nov 27, 2013 | Craftsman 16-gal 6.5-peak hp Wet/Dry Vac...
Hesco generator problems
Check the Spark plugs. Pull them out and see what they look like. Replace the ones that looks bad. Use a Spark Plug Gap Finder and make sure it is set to the specs of the generator.
Could be the Fuel itself. When was the last time you ran it out of gas and refill it? If the spark plugs are fine Empty the tank and place some fresh fuel. Clean or replace the Air filter. Do the general maintenance.
Nov 07, 2013 | Vacuums
Will not start- seems to be fuel starvation.
Hi peterblesset...
You did not give me any info on what kind of engine that is starving for fuel.
So I will give you my solution to 2 cycle some 4 cycle chainsaw and trimmer engines with fuel problems and igintion problems.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later
reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle chainsaw or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me thumbs up
Sep 13, 2011 | Vacuums
Gas to oil ratio for dayton chainsaw model 2z971
Hi montorsewill...
You will use a 50:1 Oil to gas ration...1 pint of 2 cycle oil to 6 gallons of gasoline
Sep 02, 2011 | Vacuums
How much oil would i ad to a pint of gas at a 50 to1 ratio
A pint is 16 ounces, add 1/3 ounce of oil for a 48:1 mixture.
Gary
Aug 30, 2011 | Vacuums
Need to adjust carb, wont run
Hi dbk48..
Your listing is under vacuum cleaners and I have never seen a vacuum with a carburetor.
You did not say what machine (lawnmower,weed trimmer,ect) would not run...so it is really difficult to tell you how to adjust the carburetor.
I will include some info on a trimmer/mower carburetor repair...Just guessing that is what you need.
Your problem may be more than just a carburetor adjustment...
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting a nice blue spark then:
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
Note:
Aug 17, 2011 | Vacuums
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
Will not start
Apr 14, 2009 | Vacuums
Vacuums Logo
171 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
