Question about Psi 2500 Mobile Pressure Washer 5hp Honda Engine
How much oil do i mix with the gas for a xr2500 pressure washer
That engine should be four stroke so no oil mixed with the gas.
Posted on May 29, 2012
Why does the Gas mix with oil
These are the two simplest causes:
crankcase overfill situation . . check oil level and adjust as needed.
air filter blockage causing the engine vacuum to draw from the crankcase breather and the engine oil with it.
Jul 06, 2014 | Dewalt DPD3100 Gas Pressure Washer
The pump is leaking some gray fluid
Gray fluid is usually indicative of old oil with water mixed into it. First you have to determine if the fluid is coming out of the motor or pressure pump. Then change the oil in that, or both, and then watch the condition of the oil when you use the washer. With new oil, it won't turn gray but will get a milky coloration to it. There shouldn't be any way for water to get into the motor oil short of the engine being sprayed directly with high pressure water. If water is getting into the pump oil you'll have to check the seals inside the pump.
Feb 14, 2013 | Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600...
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 | Garden
I cannot remember the type of gas or the fuel mixture (gas to oil ratio if required) for my pw2050 2000psi pressure washer,last used 2006 cannot locate the manual,
Pump regular gas and no oil mix. Your engine has a dipstick which means its a four stroke engine.
The oil goes inside the motor. For summer use I recommend 30 weight non-detergent oil.
Change it out once a season *(Beginning would be preferred). Drain the gas out at the end of the season.
Hope this helps!
Feb 23, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
Can i run plus gas in my washer
I'm not sure what you mean.
I think you are asking if your power washer needs oil mixed with the gas.
Does your machine have a oil reservoir below the engine?
If there is a place to put engine oil, then your engine runs on ordinary gasoline.
The pump oil is SAE20 or SAE30 non-detergent motor oil > oil comes up half way inside box.
The engine oil is 10W30 motor oil > oil comes up bit more than half way on dipstick
Oct 21, 2010 | Northstar Pressure Washer 3000 PSI
I would like to know if this pressure wahser use only gas or (Gas and Oil) is mixed?
If your engine has a place to put oil, then your power washer uses ordinary gasoline.
The only type engine that uses 2-cycle oil and gas mixture is engine that has no place to put oil.
Oil for pump comes half way up >>> pump uses SAE20 or SAE 30 non-detergent motor oil
Oil for engine comes half way up dip stick and uses 10-W30 motor oil
Oct 15, 2010 | Dewalt DPD3300 Commercial Pressure Washer
Oil to gas mixture for a craftsman 3.75 hp pressure washer
There is universal 2 cycle oil available (pro-mix at Lowe's for example) that is good for all ratios from 16:1 to 50:1. With this oil you add the same amount of oil to the gas independent of ratio required. One gas can, no ratio worries. Hope this helps.
Oct 03, 2009 | Briggs & Stratton Garden
Does pressure washer pumps need oil or not?
There are certain pressure washer that do require oil. It depends on your make and model of he machine.Usually they require, when it is a gas powered unit and then if its a 2 cycle gas engine they take a gas/oil mix in the tank and do not require oil in a crankcase.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2009 | Briggs & Stratton Garden
What gas and oil do I use on the Honda Excell 2600 pressure washr
That engine requires a separate gas and oil. There is an oil sump with oil level needle and cap on the side of the engine. This is where you fill it with special pressure washer pump oil available from any good outdoor store or place where pressure washers are sold. As for gas, Unleaded or Premium unleaded gas will work fine. Try not to use any fuel with ethanol blends however. Here is a list of oils that will give you an idea what to buy for the oil reservoir: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2Fs%3Fie%3DUTF8%26ref%255F%3Dnb%255Fss%255Fgw%26field-keywords%3Dpressure%2520washer%2520pump%2520oil%26url%3Dsearch-alias%253Daps&tag=onlinetoolrev-20&linkCode=ur2&camp=1789&creative=390957
Jun 14, 2009 | Honda Pressure Washer PSI 3000
Psi 2500 Mobile Pressure Washer 5hp Honda Engine Logo
502 people viewed this question
Top Psi Tools & Hardware - Others Experts
Tim Venetis
Mike Squire
Are you a Psi Tool and Hardware - Other Expert? Answer questions, earn points and help others
