Question about RCA L26W11 26 in. HD-Ready LCD Television
My tv picture is not coming on...there is a loud clicking sound when it turns on or off, i still get sound no picture though
    Genius:
  • 1,212 Answers
Most likely place to start checking is the power supply board or the inverter board if they are discrete boards.
Check fuses, they will be in the vicinity of where power enters the board(s) Then look for bulging capacitors- if you find any, replace with comparable values of same or slightly higher working voltage. And replace all in the vicnity of the failed caps. Use high ripple current types as the General purpose types you might buy at Radio Shack are just General Purpose and they do differ internally.
If those check out, or have been replaced and set still not functional, Look for resistors or diodes that are discolored (they may have failed). The power resistors are a good place to start as some double as fuses whether designed to or not.
If the set has a logged a few thousand hours and flickers, or shuts down after image begins to appear, the CCFL tubes are likely at the end of their life span as well.
Posted on Dec 18, 2011
Loud buzzing sound from tv with no picture
It sounds as though your SMPS is seriously faulty and normally one can buy a kit to correct the problem if you are a TV engineer, however there could also be many other reason for the condition that you describe its almost impossible to guess correctly, it really needs a qualified engineer to assess the problem along with he or she having the set with them.
Sep 04, 2016 | Samsung PN42C450 42 in. TV
My tv made a loud noise like a vacuum them a high pitch noise and now it wont turn on unless I keep flicking the surge protector on and off.It wont even work when plugged directly into the outlet.
Power supply...The vacuum sound you heard was a capacitor failing. A capacitor stores energy for later use. For example, you turn on your TV, seconds later you hear a "Woosh" and the picture comes up. This is your tv's capacitor discharging. It's a simple fix if you know electronics though I wouldnt recommend repairing this yourself. There are several capacitors inside your TV. Though not fatal, they can give you a jolt. Call a repair man. I hope this helps : )
Jan 07, 2011 | Televison & Video
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
Tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Apr 01, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
TV clicks off, sound comed back on but no picture
I had the same problem. I replaced 14 capacitors on the Power Supply board. I used Panasonic series FC from DigiKey. If you see any capacitors that are swollen or have any substance oozing out for sure replace them. My set had lots of the brands that are known to have problems so I replaced all of them even though I could see no obvious swelling etc. Make sure you carefully label the connectors etc when you disassemble the unit.
Mar 12, 2009 | Polaroid TLA-01911C TV
Relay "Chatter" with good picture and sound
Sanyo Model AVM-1304 This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on. I can feel the mechanical vibration on the component. The Picture and sound are very good. The chassis is G6Y-13040. Any ideas? This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on replace relay as it is easily available or make it direct. .
Sep 11, 2007 | Televison & Video
Television will not turn on
look on the rear of the set and find out what chassis in your set.
Aug 30, 2007 | RCA 32V550T 32" TV
RCA L26W11 26 in. HD-Ready LCD Television Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
