Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Hi, i was just wondering if i can't seem to find the usb icon when i plug in my external drive is there anyway i can still recover the files within the external hard drive. some poeple have told me about active file recovery and i was just wondering would i be able to recover all my files and when i saw the DEMO active file recovery, it says that it only recovers 54kb so does that mean i can only be limited to recover up to 54kb and the program wont work anymore? or does it mean that i can only recover 54kb each time? THank you!
  • 4 more comments
  • huynh_maggie May 29, 2011
    heyy hmm this isn't an internal drive within my computer, its a external drive, like my acomodata external drive's blue light turns on but it just wont connect to my computer.
    yup i have tried it but i can't seem to find any red x or anything you have said . and i updated my drivers too but still nothing works :(
    i have updated all my drivers and ididn't have any x or red or exclamation marks, but my external drive still doesn't work
    hmm i checked that already, because when i plug in another usb within the usb drive on my computer it works for other usbs but not for my external drive :(
  • huynh_maggie May 30, 2011
    my external drive is not there
  • Acomdata Master
  • 27,725 Answers
If your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 29, 2011
  • 5 more comments
    hi, hm this isn't an internal drive my acomdata is an external drive, like the blue light still turns on but it doesn't seem to connect to my computer when i connect with with a usb cord, ive changed the usb cord many times but it doesn't seem to work so i dont think its the usb cord's problem
  • Brian Sullivan
    Brian Sullivan May 29, 2011
    have you checked the drivers click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
  • Brian Sullivan
    you might check the USB leads inside your computer red-white-green-black make sure the are securely seated with no dust built up on and around them dust causes static electricity which causes computers a great deal of problems you might also check the end inside which attaches to the external hard drive
  • Brian Sullivan
    Brian Sullivan May 30, 2011
    i did that already, it still doesn't work
  • Brian Sullivan
    click start control panel administrive tools ,computer management ,device manager scroll to disk drives if you can see your drive right click to update driver also scroll to system devices if you see any exclamation or red x right click to updatedriver
External hard disk WD 500gb icon absent in my computer window?
Turn the computer off without the external hard drive being plugged in.
plug the external hard drive in a usb port, power up, the systems post boot up will find the drive and inform windows what hardware is installed.
When windows boots up, it will look at all the hardware and find the external hard drive, when windows finishes booting up you should be able to see the drive in my computer.
If you can't access your files,data recovery software can help.I used this one called Tenorshare Data Recovery to retrieve files off crashed HDD and it worked. Get it from http://www.any-data-recovery.com
If needed,you can download it and scan your hard drive for free to preview whether your files can be recovered.
Mar 29, 2012 | Western Digital WD Elements Portable...
Windows xp not recognize external hard drives
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data from hard drive with data recovery software.I had succeed with Tenorshare data recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, virus attack etc.
You can download it and scan your external hard drive for free to preview whether your files can be recovered.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to get it fixed.
Nov 05, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My windows 7 laptop suddenly doesn't read or recognize anymore my pqi HDD 551
You will need to recover the data using something like this data recovery program.
http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
Good luck.
Aug 31, 2011 | PQI 320GB H551 USB 20 Turbo Boost External...
I just got the HITACHI SimpleDrive 1TB USB 2.0 External Hard Drive HSD1000 recently and downloaded some files from a mac on to it, now I'm trying to access the information from it from a Windows &...
The external hard disk must be formated in a file system that both the pc and the mac can use - best is FAT32. In your case the file system that the mac put on the disk is incompatible with the pc.
Make sure the files you want to move are still on the mac (if not copy them back from the disk), plug the disk in the pc and format it there in FAT32 (don't use the quick option), plug it in the mac and copy the files and unmount the disk before disconnecting it from the USB connector. Now you can put it in the pc - in there always use the Safely disconnect icon, don't just yank out the cable.
Aug 15, 2011 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
Hi, hmm my external drive when i pllug it in no longer connects when ever i try to connect it to my computer. Is there anyway i can recover back all my files within my external drive ? Some people have...
I believe that the demo will only recover 54kb because it only a demo.after that it may ask you to purchase the real active file recovery software.
if in doubt it would be a good idea to take down to a IT specialist and get done properly.A few dollars is worth spending on the recovery of lost Data,aye??
G.
May 29, 2011 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
I can't access my wd external hard disk (passport )through (my computer) i can see it using windows disk management as unallocated partition...when right clicking..no options are active but properties
Hello
Have you tried accessing the hard drive on another computer?
Have you tried using a different USB cable?
Was the hard drive dropped or moved while it was plugged in?
Check the WD Site if you hard drive has warranty.
I hope this solves your problem and please reply if you need more help.
May 11, 2011 | Western Digital Passport WDXML800UE...
Hi mate i have a wd passport hd, and i took it out when my computer wa restarting. and now my computer and any other computer dont read it it say reformat. it has very importent files on how can i retrive...
Here is a 10 day free trial of a software recovery program that can be burned to a disk. You would then boot from that disk with your external drive plugged in, and after it loads the software, tell it to find all available files. When you find your files, copy them to your regular hard drive and reformat the external. Copy the files back to your external drive. Hope that helps some.
http://www.ntfs.com/products.htm
May 03, 2011 | Western Digital Passport 320GB External...
External hard drive does not display icon in My Computer
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
Mar 03, 2009 | Verbatim 160GB USB FireLite: The "drive...
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
