My frigidaire air conditioner stopped working. All lights are on and the ac is not responsive. I had this happen couple of days ago and after approximately 12 hours, it started working again. any idea what that may be?
Ice maker
  • 8 Answers
SOURCE: Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Posted on Mar 30, 2008
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
jerryg50
  • 1667 Answers
SOURCE: No water
If the air conditioner is putting out cold air, don't worry about it making water. You may not have enough moisture in the air to produce more water than it requires.
In some types of air conditioners, the water taken from the air is used to assist in cooling the condenser unit. The excess is run off.
Jerry G.
Posted on Jul 01, 2008
  • 439 Answers
SOURCE: Central air/heat pump not putting out cold air
I have some things for you to check. If you look at the outside unit the lines going into the house. Are they frozen? Have you had any yard work done, the reason I ask is they could have accidentally cut or pulled out the thermostat wires to the ac unit. Also, inside check for the same thing, frozen lines. Also, you may want to check the drain coming from the inside unit, it may be clogged.
Posted on Jun 22, 2009
SOURCE: Electronic control on Frigidaire air conditioner not working
which one take live or nuetral ?
common
start
run
thanks
Posted on Jul 11, 2009
My frigidaire AC starts cooling fine but stops blowing cold air after few minutes and it does not cool at all. I haved turned it off and re-started it and it does the same thing
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Aug 17, 2016 | Frigidaire FAS256R2A 25,000 BTU Window Air...
Have a frigidare wall ac (FAA067P7A). Worked 1st year we had it but problems after. Only time compressor kicks in is when we hit reset button. Then cold air comes out for couple minutes then compressor...
The compressor is stopping on overload. There is either a weak breaker or an electrical problem causing the overload to open the circuit and stop the compressor. It has to be taken apart to determine what is or is not going on.
Aug 03, 2011 | Frigidaire Compact Air Conditioner
I have a brand new frigid air cinditioner and it is not cooling, i got it 2 days ago and it's on 24/7
If you have a unit that has stopped cooling in a couple of days... tkae it back and get another one...you got a lemon...
do not mess with it or tear it apart... just put it back in the box and return it for another one...
heatman101
Aug 31, 2010 | Frigidaire FAC084N7A Air Conditioner
Everstar portable AC not cooling, what do I do?
Same thing happened a few weeks ago. My wife said " its not cooling". I read the manual and it says., Clean filters ...we did and hello. works fine. She was so frustrated she was going to take it back. These filters accummulate dust fast. So check there first. Hope this helps.
I would lkike to know where to get replacement filters or an extension exhaust duct.
Aug 29, 2009 | Danby DPAC8020 Air Conditioner
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Outside unit not working
you most likely need a service guy to go out and take a look
Mar 15, 2009 | Fujitsu 18C1 Air Conditioner
Frigidaire FAC125P1A6 when AC is on mist is coming out
Try cleaning the filters and running a couple of degrees warmer. If this does not work have the refrigerant levels checked by a professional.
Jul 06, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
