Question about Harman Kardon SoundSticks Computer Speakers
Went on vacation, came home and now speakers won't work. subwoofer blue light is on and everything is connected right. what could be the problem?
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 30, 2011
I have a blue pyle 12 inch 800 watt tube for my car. I've wired everything perfectly, yet when I go to turn on my radio, it doesn't work. The blue lights cut on, but the speaker itself puts out...
it could be few things one the light might come on but the preamp could be bad two could be a loose wire to sub three sub could be bad four make sure rca cables are good i hop this helps
Feb 21, 2013 | Car Audio & Video
How do i fix an output problem?
is the cone stuck form lack of use by any chance ,try connecting to a car battery and touching a wire to complete the circuit quickly and it should go blurp if its working and this often frees the cone up if its a bit corroded
Dec 02, 2011 | Infinity KAPPA PERFECT 12.1 Car Subwoofer
Splice Bose speaker to connect to receiver
Each speaker has two 4 Ohm drivers. Each speaker has a connector with 4 pins. From left to right they are + - - +. Say 1 2 3 4 . If you want a 8 Ohm speaker connect 2 and 4 together. Now 1 goes to your amplifier (+) and 3 to your amplifier (-). In yor case join black with blue. Now red goes to the amplifier red and green to the amplifier black.
Nov 27, 2011 | Bose Cinemate Digital Home Theater System...
I have a 1990 Celica, trying to put in new radio. Got everything wired up correctly, Constant - blue/yellow, acc - gray, ground - brown and it won't come on. Radio fuse (top center 15 amp) is good,...
You have it right. Use a 12 volt test light to see if there is power between the gray and brown wires when the key is on. If there is power there, you may have got hold of a bad radio.
1990 Toyota Celica Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow, connects to yellow
Radio Switched 12V+ Wire: Gray, connects to red
Radio Ground Wire: Brown, connects to black
Radio Illumination Wire: Green, do not use
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Oct 29, 2011 | 1990 Toyota Celica
Have a 1996 Toyota Camery. Installed a KDG140 JVC stereo/CD player but the stereo won't work. CD player works great.
If "stereo won't work" refers to you not being able to get radio stations; try your antenna connection behind the radio. The vehicle may also have a power antenna connection(blue wire at the stereo).
Jul 28, 2011 | Car Audio & Video
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
My subwoofer and wireless speakers won't sync lhb975 blinks blue then turns red
http://www.avsforum.com/t/1386546/lg-lhb975-wireless-speaker-sync-repair Te solution is here
Jul 18, 2011 | LG LHB975 Theater System
Car was working fine then i went out again it started then cut off and now won't start everything's fine only thing went wrong power windows stopped and power windows stopped working also before...
Sounds like possible fusible link is blown or lose?
Fusible links are different then regular fuses found in fuse box and are located under the hood near the battery ..
Did you just install the system ? or has system already been installed for a while and this problem just occurred ?
May 15, 2011 | Car Audio & Video
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
Harman Kardon SoundSticks Computer Speakers Logo
157 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
